[Liblas-devel] configure error using trunk
Volker Wichmann wichmann at laserdata.at
Wed Jul 1 03:51:00 EDT 2009
On 06/30/2009 07:07 PM, Howard Butler wrote:
> On Jun 30, 2009, at 5:35 AM, Volker Wichmann wrote:
>> Hi,
>> I just did a fresh svn checkout, trunk revision 17322. After
>> autoreconf, configure results in the following error:
>> checking for debug enabled... no
>> checking for GDAL... no
>> checking for libgeotiff... no
>> checking for spatialindex RTree.h... no
>> checking for libspatialindex... no
>> ./configure: line 16716: syntax error near unexpected token
>> `$ORACLE_OCI_REQ_VERSION'
>> ./configure: line 16716: `AX_LIB_ORACLE_OCI($ORACLE_OCI_REQ_VERSION)'
> Volker,
> Can you rerun ./autogen.sh and see if that cures things?
> Howard
Thanks Howard, that solved the issue!
Volker
More information about the Liblas-devel mailing list
