[Liblas-devel] Build errors while building apps
Froumis, James A (US SSA)
james.froumis at baesystems.com
Thu Jul 16 19:47:23 EDT 2009
Hello,
I'm getting the following build errors while the apps are compiling in
liblas 1.2.0 on 64-bit Linux:
../src/.libs/liblas.so: undefined reference to
`SetGeogCSCitation(gtiff*, OGRSpatialReference*, char*, int, short)'
../src/.libs/liblas.so: undefined reference to `SetCitationToSRS(gtiff*,
char*, int, geokey_t, OGRSpatialReference*, int*)'
`SetLinearUnitCitation(gtiff*, char*)'
`GetGeogCSFromCitation(char*, int, geokey_t, char**, char**, char**,
char**, char**)'
I configured liblas using this command:
./configure --with-gdal=/usr/local --with-geotiff=/usr/local
Which prints this configuration at the end:
libLAS configuration summary:
Version..................: 1.2.0
Installation directory...: /usr/local
C compiler...............: gcc -Wall -Wno-long-long -pedantic -O3
-DNDEBUG
C++ compiler.............: g++ -Wall -Wno-long-long -pedantic
-std=c++98 -O3 -DNDEBUG
Debugging support........:
GDAL support.............: yes
- gdal-config...........: /usr/local/bin/gdal-config
- INCLUDE directories...: -I/usr/local/include/gdal
GeoTIFF SRS support......: yes
- libgeotiff............: external
- INCLUDE directories...: -I/usr/local/include/geotiff
LIBS.....................: -L/usr/local/lib -lgeotiff -L/usr/local/lib
-lgdal
I have version 1.2.5 of libgeotiff, and version 1.6.0 of libgdal, and
they were both built on this same machine.
Any ideas what might be causing this link error? I have used this same
configuration command and libgdal / libgeotiff libraries to build
previous versions of liblas (1.0.0) with no problems.
Thank you,
Jim Froumis
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20090716/1f541fef/attachment.html
More information about the Liblas-devel
