[Liblas-devel] LAS file Coordinate Systems
Mateusz Loskot
mateusz at loskot.net
Wed Jul 22 19:47:51 EDT 2009
Patel, Ronak Avinash \(US SSA\) wrote:
> Howard,
> I am trying to set everything in WGS 84 as you described but I am seeing
> some weird things:
> I am setting my bounding box to the following envelope:
> {-2.68934056019039, 51.501158065529, 56}
> {-2.68570637283357, 51.5034265277949, 56}
> However, when I output the las I made using lasinfo.exe (from libLAS
> 1.2) it truncates the precision and only shows
> min x y z -2.689341 51.501158 0
> max x y z -2.685706 51.503427 0
lasinfo does the rounding:
http://liblas.org/browser/trunk/apps/lascommon.c#L281
This 6 decimal points is a reasonable choice of precision
used to present float-point value for data inspection purpose.
The libLAS, the library, does not (should not) do any rounding.
Best regards,
Mateusz Loskot
http://mateusz.loskot.net
More information about the Liblas-devel
