[Liblas-devel] LAS file Coordinate Systems
Patel, Ronak Avinash (US SSA)
ronak.patel at baesystems.com
Thu Jul 23 16:57:51 EDT 2009
Howard,
So I see the Geotiff spec describe the GeoKeyDirectoryTag Record tag at:
http://remotesensing.org/geotiff/spec/geotiff2.4.html as
GeoKeyDirectoryTag=( 1, 1, 2, 6,
1024, 0, 1, 2,
1026, 34737,12, 0,
2048, 0, 1, 32767,
2049, 34737,14, 12,
2050, 0, 1, 6,
2051, 34736, 1, 0 )
GeoDoubleParamsTag(34736)=(1.5)
GeoAsciiParamsTag(34737)=("Custom File|My Geographic|")
I am writing:
(1, 1, 0, 4)
(1025, 0, 1, 2)
(1024, 0, 1, 2)
(2048, 0, 1, 4326)
(4097, 0, 1, 9001)
In code this translates to:
final ByteBuffer wrap = ByteBuffer.allocate(40);
wrap.putShort((short) 1);
wrap.putShort((short) 0);
wrap.putShort((short) 4);
wrap.putShort((short) GeoTiffConstants.GTRasterTypeGeoKey);
wrap.putShort((short) GeoTiffConstants.RasterPixelIsPoint);
wrap.putShort((short) GeoTiffConstants.GTModelTypeGeoKey);
wrap.putShort((short) GeoTiffGCSCodes.ModelTypeGeographic);
wrap.putShort((short) GeoTiffGCSCodes.GeographicTypeGeoKey);
wrap.putShort((short) GeoTiffGCSCodes.GCS_WGS_84);
wrap.putShort((short) GeoTiffVCSCodes.VerticalCitationGeoKey);
wrap.putShort((short) GeoTiffUoMCodes.Linear_Meter);
Does this make sense? It does according to page 14 of the LAS 1.2
spec....
If so, why does lasinfo.exe say that it can't read this tag?
-----Original Message-----
Sent: Thursday, July 23, 2009 1:30 PM
To: Patel, Ronak Avinash (US SSA)
Cc: Liblas-devel at lists.osgeo.org
Subject: Re: [Liblas-devel] LAS file Coordinate Systems
Are you by chance confusing LAStools with libLAS?
LAStools has a partial implementation of some geotiff key reading/
writing. libLAS, which implements the command line utilities of
LAStools, uses libgeotiff for geotiff key reading/writing and provides
a much more complete implementation.
Your results will differ depending on which one (LAStools or libLAS)
you are using.
Howard
On Jul 23, 2009, at 3:00 PM, Patel, Ronak Avinash (US SSA) wrote:
> I am using lasinfo.exe to display the fields. I downloaded lastools
> separately for Windows.
> From: liblas-devel-bounces at lists.osgeo.org
> [mailto:liblas-devel-bounces at lists.osgeo.org] On Behalf Of Howard
> Butler
> Sent: Thursday, July 23, 2009 12:55 PM
> To: Liblas-devel at lists.osgeo.org
> On Jul 23, 2009, at 1:39 PM, Patel, Ronak Avinash (US SSA) wrote:
>> Howard and Mateusz,
>> Thanks for the help...really appreciate it. Haven't really found many
>> people out there that know the low levels as much as you guys do.
>> I was looking at the LAS 1.2 spec and it says the Georeferencing
>> information requires the GeoKeyDirectoryTag Record.
>> I am able to write that tag out but I see that lasinfo always shows
>> the
>> version to be 0.0.0 regardless of what I put in those fields.
>> According to the spec, the data should be arranged:
>> wKeyDirectoryVersion = 1 (2 bytes)
>> wKeyRevision = 1 (2 bytes)
>> wMinorRevision = 0 (2 bytes)
>> wNumberOfKeys = the number of sets of 4 unsigned shorts to follow
>> I write out the above shorts and 0 out the rest of the data byte
>> array
>> but lasinfo always shows 0.0.0 as the version.
>> Is the spec wrong? Or is something else going on here that lasinfo
>> and
>> libLAS are doing??
> Are you linking libLAS with libgeotiff when you compile? libLAS
> completely ignores georeferencing if libgeotiff is not linked at
> compile time.
> Howard
> Liblas-devel mailing list
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
