[Liblas-devel] Build errors while building apps
Froumis, James A (US SSA)
james.froumis at baesystems.com
Thu Jul 23 17:38:08 EDT 2009
Howard,
Thanks for the help. Unfortunately, downloading and installing the
latest version of libgdal (1.6.1) and using the configure arguments you
specified did not solve the problem. I am still getting the same errors.
Is there something else I am missing?
Thanks,
Jim Froumis
> James,
> Please subscribe to the mailing list before posting.
> Try configuring --with-gdal=/usr/local/bin/gdal-config
> Additionally, these errors usually mean that the GDAL version is too
old (I think 1.6+ is required). > I hope to fix this in a 1.2.1 release
to add these functions if they are not available.
> Hope this helps,
> Howard
On Jul 16, 2009, at 6:47 PM, Froumis, James A (US SSA) wrote:
>> Hello,
>> I'm getting the following build errors while the apps are compiling
in
>> liblas 1.2.0 on 64-bit Linux:
>> ../src/.libs/liblas.so: undefined reference to
>> `SetGeogCSCitation(gtiff*, OGRSpatialReference*, char*, int, short)'
>> `SetCitationToSRS(gtiff*, char*, int, geokey_t, OGRSpatialReference*,
>> int*)'
>> `SetLinearUnitCitation(gtiff*, char*)'
>> `GetGeogCSFromCitation(char*, int, geokey_t, char**, char**, char**,
>> char**, char**)'
>> I configured liblas using this command:
>> ./configure --with-gdal=/usr/local --with-geotiff=/usr/local
>> Which prints this configuration at the end:
>> libLAS configuration summary:
>> Version..................: 1.2.0
>> Installation directory...: /usr/local
>> C compiler...............: gcc -Wall -Wno-long-long -pedantic -O3
>> -DNDEBUG
>> C++ compiler.............: g++ -Wall -Wno-long-long -pedantic -
>> std=c++98 -O3 -DNDEBUG
>> Debugging support........:
>> GDAL support.............: yes
>> - gdal-config...........: /usr/local/bin/gdal-config
>> - INCLUDE directories...: -I/usr/local/include/gdal
>> GeoTIFF SRS support......: yes
>> - libgeotiff............: external
>> - INCLUDE directories...: -I/usr/local/include/geotiff
>> LIBS.....................: -L/usr/local/lib -lgeotiff -L/usr/local/
>> lib -lgdal
>> I have version 1.2.5 of libgeotiff, and version 1.6.0 of libgdal, and
>> they were both built on this same machine.
>> Any ideas what might be causing this link error? I have used this
same
>> configuration command and libgdal / libgeotiff libraries to build
>> previous versions of liblas (1.0.0) with no problems.
>> Thank you,
>> Jim Froumis
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20090723/6c0ebb9b/attachment-0001.html
More information about the Liblas-devel
