[Liblas-devel] txt2las - psid only 1 byte?
Volker Wichmann
wichmann at laserdata.at
Fri Jun 5 05:48:57 EDT 2009
I have troubles converting an ASCII file with point source ids > 254 to
LAS 1.1 using the txt2las tool (version 1.2.0b3). It seems to me, that
the point source id is not written as unsigned short (2 bytes) but as
unsigned char (1 byte) resulting psid=0. Is anybody experiencing the
same problem?
Thanks,
Volker
PS: I obtain correct results using the old lastools txt2las from Martin
Isenburg
More information about the Liblas-devel
