[Liblas-devel] txt2las - psid only 1 byte?
Volker Wichmann wichmann at laserdata.at
Mon Jun 8 11:54:08 EDT 2009
Howard Butler wrote:
>>>>> You will need to run ./autogen.sh as automake and libtoolize need
>>>>> to be rerun due to some new macros being implemented.
>>>>> Howard
>>>> Thanks, that worked. Also the psid seems to be written correctly
>>>> now - I just did a quick check with lasinfo. But I had to use an
>>>> older version of lasinfo to get it printed, it would be nice if the
>>>> version in trunk could be extended to print it again.
>>> hmm... do you think that lasinfo is interpreting it as a byte
>>> instead of a short?  Please add more details to that bug and I will
>>> look into it.
>>> Howard
>> it isn't printed at all - so this is more a feature request than a
>> bug report. Maybe it was just overlooked when the lasinfo output was
>> changed to use the --check flag.
> Ah, yes, it probably isn't printed or cumulated at all.  Please file a
> bug for that in the Utilities component and I will try to get to it
> for the 1.2.1 release.
I've filed a bug on that issue. Also took the freedom to close ticket
#139 (txt2las psid > 255) as it seems to be fixed.
Thanks,
Volker
More information about the Liblas-devel mailing list
