[Liblas-devel] point source id
Howard Butler hobu.inc at gmail.com
Mon Mar 30 14:00:36 EDT 2009
On Mar 30, 2009, at 12:07 PM, Mateusz Loskot wrote:
> Volker Wichmann wrote:
>> Hi,
>> I've a question regarding the handling of the point source id:
>> I just realized that neither txt2las nor las2txt support psid, the
>> corresponding code seems to be commented out in trunk. Is there any
>> reason for this?
> What corresponding code you are referring to?
> Recently, Point Source ID access has been implemented:
> http://liblas.org/ticket/87
> http://liblas.org/ticket/115
It is commented out because the Point Source ID stuff didn't exist
until 1.2, but it didn't make it into las2txt and txt2las for the 1.2
release.
I have fixed this issue in both trunk and the 1.2 branch http://liblas.org/ticket/121
   If it is convenient for you to build from source, I would suggest
checking out a copy of the code from subversion http://liblas.org/svn/trunk
Thanks for the report,
Howard
More information about the Liblas-devel mailing list
