[Liblas-devel] Re: las2ogr question.
Howard Butler hobu.inc at gmail.com
Thu May 21 15:43:34 EDT 2009
On May 21, 2009, at 2:32 PM, Frank Warmerdam wrote:
> Jeff Hamann wrote:
>> Frank,
>> I was trying to use the las2ogr tool, and wanted to export the
>> results to a PostGIS database I have developed and noticed that the
>> las2ogr tool only exported shapefiles. I've had some experience
>> adding additional tags (timestamps) into the KML outputs for OGR,
>> but haven't worked with much of the gdal/ogr code beyond that. I
>> think I've got the chops to wire it up, but have no time (read
>> cash) to pay for it and so I've decided I have to do it myself. I
>> know I can export the las files to shapefiles, and import the
>> shapefiles that way, but would like to read the las files directly
>> into my database. Any suggestions would be great and I would like
>> to contribute to gdal/ogr very much.
> Jeff,
> I have taken the liberty of cc:ing Howard Butler who I presume is
> the author
> of las2ogr.
> In *theory* it should be pretty straight forward to alter the las2ogr
> code a bit to use the PG driver instead of the "ESRI Shapefile"
> driver.
> Actually, looking at the code:
>  http://liblas.org/browser/trunk/apps/las2ogr.cpp
> It seems it already supports selecting alternate output drivers.
> However,
> it assumes it will always be creating the target datasource object
> while
> in the case of PostGIS we will want to open an existing database and
> just
> create a new layer.
> Try altering:
>        OGRSFDriverH drv = OGRGetDriverByName(out_frmt.c_str());
>        if (0 == drv)
>            throw std::runtime_error(out_frmt + " driver not
> available");
>        ogr_wrapper<OGRDataSourceH> ds(OGR_Dr_CreateDataSource(drv,
> out_file.c_str(), 0), OGR_DS_Destroy);
> To something like:
>  ogr_wrapper<OGRDataSourceH> ds( OGROpen( out_file.c_str(), TRUE,
> NULL ));
> Assuming out_file is the name of a postgres database - something like
> "PG:dbname=warmerda ...", then it should be opened in update mode.
> Then
> (hopefully) all the rest of the stuff will just work.
Mateusz was actually the author of las2ogr.
These types of questions would best be asked on the liblas-devel
mailing list http://lists.osgeo.org/mailman/listinfo/liblas-devel ,
which I have cc'd here in case other wonder about such an issue.
We would gladly take a patch that would notices the user attempting to
use the PostGIS driver and switch from doing a CreateDataSource to an
OGROpen as appropriate.
Thanks,
Howard
More information about the Liblas-devel mailing list
