[Liblas-devel] liblas+gcc42+FreeBSD64 + stdint.hpp
Jeff Hamann jeff.hamann at forestinformatics.com
Tue May 26 23:50:08 EDT 2009
LibLAS developers:
After receiving a few suggestions, I attempted to hack at the
Makefiles to get it to build with a more recent compiler, at least
more recent that gcc 3.4. Hacking absolute pathnames in the post ./
configure Makefiles didn't seem to fix the problem. Then I tried using
$ ./configure CC=/usr/local/bin/gcc42 CXX=/usr/local/bin/g++42 F77=/
usr/local/bin/gfortran42
which resulted in the following config:
libLAS configuration summary:
   Version..................: 1.0.1
   Installation directory...: /usr/local
   C compiler...............: /usr/local/bin/gcc42 -Wall -Wno-long-
long -pedantic  -O3 -DNDEBUG
   C++ compiler.............: /usr/local/bin/g++42 -Wall -Wno-long-
long -pedantic -std=c++98  -O3 -DNDEBUG
   Debugging support........:
   GDAL support.............: no
   GeoTIFF SRS support......: no
   LIBS.....................:
   libLAS - http://liblas.org
still yields the following results for a sample file:
bobby# ./lasinfo lidar.las
   Header Summary
   File Name: lidar.las
   Version:                    1.0
   Source ID:                  0
   Reserved:                   0
   Project ID/GUID:           '00000000-0000-0000-0000-000000000000'
   System Identifier:         ''
   Generating Software:       'TerraScan'
   File Creation Day/Year:    0/0
   Header Size                227
   Offset to Point Data       -452984832
   Number Var. Length Records 0
   Point Data Format          1
   Point Data Record Length   28
   Number of Point Records    -261525504
   Number of Points by Return 0 -783548416 295895808 -1851190784
2110806272
   Scale Factor X Y Z         7.68817e+284 7.68817e+284 7.68817e+284
   Offset X Y Z               0.000000 0.000000 0.000000
   Min X Y Z                  0.000000 0.000000
738736861263988851298380279202391078391644568474981382591204550317796735641019245818295007277452811570850587484972658344932700484666392576.000000
   Max X Y Z                  0.000000 -0.000000 -0.000000
  Spatial Reference
bobby#
To facilitate some testing, I need to build this on FreeBSD. liblas
works fine on OSX (gcc 4.0.1).
Is there some problem with the resulting  "-Wno-long-long" and include/
liblas/cstdint.hpp entries?
Thanks,
Jeff.
More information about the Liblas-devel mailing list
