[Liblas-devel] libLAS 1.2.1
Howard Butler hobu.inc at gmail.com
Fri Oct 2 14:12:45 EDT 2009
All,
10/2/2009
The libLAS team is pleased to announce the maintenance release of
libLAS 1.2.1  This release fixes seventeen bugs:
* http://liblas.org/ticket/120 - support 'comma' as a separator in
las2txt
* http://liblas.org/ticket/121 - las2txt and txt2las don't work with
the Point Source ID
* http://liblas.org/ticket/122 - las2las does not eliminate requested
classifications
* http://liblas.org/ticket/124 - some files have pad bytes when they
shouldn't
* http://liblas.org/ticket/127 - Scan flags is order sensitive
* http://liblas.org/ticket/129 - Version.rc doesn't make the release
* http://liblas.org/ticket/132 - Require libgeotiff when GDAL is
requested
* http://liblas.org/ticket/133 - FreeBSD endian.hpp
* http://liblas.org/ticket/134 - GDAL transform translates the points
incorrectly when there is a scale or translation on the points
* http://liblas.org/ticket/136 - Problem overwritting Reader's
dataoffset due to VLR
* http://liblas.org/ticket/139 - txt2las is not setting the point
source id correctly for values > 255
* http://liblas.org/ticket/140 - liblas 1.2 linking problems due to --
with-hide-internals gdal option
* http://liblas.org/ticket/141 - lasinfo in not reporting info about
point source id
* http://liblas.org/ticket/143 - libLAS 1.2 requires GDAL 1.7
(unreleased)
* http://liblas.org/ticket/144 - Apps should take in filenames without
-i argument
* http://liblas.org/ticket/145 - Memory leak from LASWriter /
lasspatialreference assignment operator=
* http://liblas.org/ticket/148 - No prototype in core.py for
LASPoint_Destroy
Links to source code and binaries are available from <http://liblas.org/wiki/1.2.1
 > or from updating your OSGeo4W <http://trac.osgeo.org/osgeo4w/>
install if you are using that.  Python bindings can be obtained from
OSGeo4W or from PyPI (no GDAL support) <http://pypi.python.org/pypi/libLAS
 > if you want libLAS in your own Python install.
Thanks to all who provided bug reports and patches!
Howard
More information about the Liblas-devel mailing list
