[Liblas-devel] CMake working for current source?
Dan Bellinski Dan.Bellinski at Woolpert.com
Thu Apr 8 10:01:06 EDT 2010
Great thanks a lot! I was able to compile successfully (the only problem now
I am having is a manifest linking issue with MSVCR80.dll when trying to run
the built .exes.. but that's something with Visual Studio I need to figure
out..)
Dan Bellinski wrote:
> Hey Howard and or Mateusz,
> I have been trying to compile the current source every so often for a
> week or so and always get the output with errors:
> Searching for GeoTIFF 1.2.5+ library
> Trying OSGeo4W using default location OSGEO4W_ROOT=c:/OSGeo4W
> Found GeoTIFF version: 1.2.5
> Found GeoTIFF: C:/OSGeo4W/lib/geotiff_i.lib
> Looking for ST_Create
> Looking for ST_Create - found
> Could NOT find TIFF (missing: TIFF_LIBRARY TIFF_INCLUDE_DIR)
> Searching for GDAL 1.6.0+ library
> NOTE: Required version is not checked - to be implemented
> Found GDAL: C:/gdal-1.7.1/gdal_i.lib
> Looking for OSRSetEquirectangular2
> Looking for OSRSetEquirectangular2 - found
> Enable libLAS utilities to build - done
> Generating Visual Studio 10 user-specific settings in
> lasinfo.vcproj.SAVIG-0123.SaVig 0123.user
> lasmerge.vcproj.SAVIG-0123.SaVig 0123.user
> las2las.vcproj.SAVIG-0123.SaVig 0123.user
> las2txt.vcproj.SAVIG-0123.SaVig 0123.user
> txt2las.vcproj.SAVIG-0123.SaVig 0123.user
> las2ogr.vcproj.SAVIG-0123.SaVig 0123.user
> CMake Error at C:/Program Files/CMake
> 2.8/share/cmake-2.8/Modules/CPack.cmake:762 (message):
> CPack package description file: "README.txt" could not be found.
> Call Stack (most recent call first):
> C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/CPack.cmake:766
> (cpack_check_file_exists)
> CMakeLists.txt:309 (INCLUDE)
> CPack readme resource file: "README.txt" could not be found.
> C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/CPack.cmake:768
> CMake Error: The following variables are used in this project, but they
> are set to NOTFOUND.
> Please set them or make sure they are set and tested correctly in the
> CMake files:
> TIFF_LIBRARY (ADVANCED)
> linked by target "las_c" in directory C:/liblas/src
> linked by target "las2ogr" in directory C:/liblas/apps
> Configuring incomplete, errors occurred!
> Is the build working for you or is it still a WIP? I am running it
> through the CMake 2.8.1 gui. Also I know I have libtiff (with source
> too) installed from OSGeo4w but it can't find it. I was having the same
> problem when using my own gdal/libgeotiff/libtiff all compiled from
> source.
> Thanks!
> Dan
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
View this message in context: http://n3.nabble.com/Liblas-devel-CMake-working-for-current-source-tp702989p706020.html
Sent from the libLAS Developers mailing list archive at Nabble.com.
More information about the Liblas-devel mailing list
