[Liblas-devel] liblas fails to compile
Tommy Stehle TStehle at HNTB.com
Mon Aug 23 14:53:50 EDT 2010
I re-pulled everything again and the errors from the index files are gone.  It seems to have trouble linking the las2las program...The compile results are attached...
Tommy
-----Original Message-----
Sent: Monday, August 23, 2010 12:18 PM
To: Tommy Stehle
Cc: liblas-devel at lists.osgeo.org
Subject: Re: [Liblas-devel] liblas fails to compile
It seems that gcc 4.4 is pickier about qualifying the names.  Can you put a
using namespace boost;
at the top of indexcell.hpp indexoutput.hpp and lasindex.hpp as needed?  Please report back.  I will go through and qualify the integer names.
Howard
On Aug 23, 2010, at 11:54 AM, Tommy Stehle wrote:
> My gcc version is 4.4.3-4.  The error list is attached...
> Tommy
> From: Howard Butler [mailto:hobu.inc at gmail.com]
> Sent: Monday, August 23, 2010 11:33 AM
> To: Tommy Stehle
> On Aug 23, 2010, at 11:29 AM, Tommy Stehle wrote:
>> I re-pulled and updated everything and I am still receiving the same errors...
> Can you list what the compile errors are?  Which gcc version(s)? I am only building on windows and osx today.  I haven't done a linux build.
> Howard
> This e-mail and any files transmitted with it are confidential
> and are intended solely for the use of the individual or entity
> to whom they are addressed.
> If you are NOT the intended recipient or the person responsible for
> delivering the e-mail to the intended recipient,
> be advised that you have received this e-mail in error and that any use,
> dissemination, forwarding, printing or copying this e-mail is strictly prohibited.
> <make.out>
Type: application/octet-stream
Desc: make2.out
Url : http://lists.osgeo.org/pipermail/liblas-devel/attachments/20100823/3f5f4e94/make2.obj
More information about the Liblas-devel mailing list
