[Liblas-devel] Offset to Point Data Bug
Howard Butler
hobu.inc at gmail.com
Thu Dec 2 16:24:35 EST 2010
On Dec 2, 2010, at 1:57 PM, Black, Tim wrote:
> For a quick fix here, I’ve add an “else” block locally:
> if (m_pointCount != 0)
> m_ofs.seekp(0, std::ios::end);
> else
> m_ofs.seekp(0, m_header.getDataOffset();
I have created <http://trac.liblas.org/ticket/195> as record of this problem, and it has been fixed in <http://trac.liblas.org/changeset/16c33aa5bf9d1b371716930ef17b7e40688d3350> with a test case added to the test suite to continually test this scenario. It will be released as part of 1.6.0b3.
Thank you for the report, and I'm sorry if you had to burn a bunch of time digging into it.
Howard
More information about the Liblas-devel
