[Liblas-devel] Performance hit from 1.21 to 1.6b3
Howard Butler
hobu.inc at gmail.com
Fri Dec 17 12:23:16 EST 2010
On Dec 17, 2010, at 10:16 AM, Mauricio Terneus wrote:
> Anyone notice a performance hit going from 1.21 to 1.6b3?
> With 1.21 I can load roughly 10 million points in 3 seconds using c api
> In 1.6b3 I load the same data set in 5 seconds using the c++ api
There have been some changes that will negatively affect performance, especially if things aren't done in ways that I have expected. I'll outline what those changes were, and some things you can do to hopefully mitigate them. I suspect there are also more places we might be able to squeeze more juice out of the lemon, as it were.
libLAS 1.2.1 and below utilized a liblas::Point that was kind of fat. It carried around interpreted data members for all of the dimensions on the point -- x, y, z, intensity, etc -- and if you asked for one of these, it just returned it to you directly. The interpretation of those data happened as the data were read, and again as the data were written (back into raw bytes).
libLAS 1.6+ has changed liblas::Point in a number of important ways. liblas::Point now only carries along the raw bytes for the point, and if you ask for one of the dimensions, it interprets it on-the-fly. For example, a GetX() call now requires going into the liblas::Point byte array, pulling the first four bytes off of it, asking the point's header for scaling information, and rescaling the integer data into double data. As you only call GetX() one time, things are roughly equivalent to what we were doing before -- interpreting and caching interpreted data directly on the liblas::Point -- but every one of your subsequent calls to GetX() have this interpretation performance hit. You need to cache your calls to interpreted data if you are reusing things.
The rationale for moving to this approach was three-fold. First, the LAS committee continually adds new dimensions onto the specification, and I wanted an extendable way to add them to libLAS without causing a full re-engineering of the liblas::Point class every time they do. Second, liblas::Point now has a schema attached to it (based on the list of dimensions that a LAS file's point format defines plus any custom dimensions you wish to add to the point record). The schema allows you to extend the point format and add your own dimensions and it provides generic descriptive information about what exists in the file. You can see the description of these schemas in the new lasinfo output from libLAS. Lastly, previous versions of libLAS did not allow you to work with raw data, and did not allow the user to transform the data (coordinate data, especially) with perfect fidelity. The new approach explicitly supports this out-of-the-box. Here's something that is now possible with the new (C++) API that was not previously:
liblas::Point const& p = reader.GetPoint();
std::vector<uint8_t> data = p.GetData();
... // do something with the raw data like stuff it into a database.
One area of the code that I suspect is performance sensitive, but I haven't done a lot of profiling of, is the portions of liblas::Point that determine where in the point's byte array to fetch the dimension from. Currently, for fixed-schema point formats, this is likely doing unnecessary work (the point formats are fixed and cannot change position). I will look into that and see if my raw i/o timings match yours and if I can improve them in any way. If you have call stacks or other profiling information, I would be excited to see what it might show. Find me on IRC to discuss some more today if you're interested.
Thanks,
Howard
More information about the Liblas-devel
