[Liblas-devel] Vertical Coordinate Systems in LAS format
Mateusz Loskot mateusz at loskot.net
Mon Jan 11 16:09:01 EST 2010
Mateusz Loskot wrote:
> Howard Butler wrote:
>> On Jan 11, 2010, at 12:45 PM, Frank Warmerdam wrote:
>>> Folks,
>>> I have been working on adding support for reading and writing vertical
>>> datums
>>> with liblas in .las files.  I have written up a sort of general
>>> information
>>> page on the effort, the tags used, and the suggested interface changes
>>> to liblas at:
>>>  http://liblas.org/wiki/VerticalCS
>>> I am seeking feedback on the planned use of geotags for vertical
>>> coordinate
>>> systems, and the proposed interfaces within liblas.
>>> I do have this all implemented now, but there is certainly room to make
>>> adjustments before it is committed.
>> +1 from me.  Implement and push up to the main repository at your
>> leisure.
> +1 from me as well.
>> I would like to see a bool LASSpatialReference::HasVerticalCS()
>> implemented as well so that a user would be able to determine the
>> verticalness of their SRS and alter their execution path accordingly.  I
>> don't know if that would be merely a lookup of the VerticalWKT for
>> VERT_CS, or something more sophisticated.  I don't like the name
>> GetWKTWithVerticalCS, though I can't think of a better one.
> I proposed on #liblas to merge the functions:
> GetWKT(bool vertical = false)
> or, even more clear to users, with enum:
> // defined in LASSpatialReference class
> enum SpatialReferenceType
>    eHorizontal, eVertical
> LASSpatialReference::GetWKT(SpatialReferenceType type) { ... }
Correction:
LASSpatialReference::GetWKT(SpatialReferenceType type = eHorizontal) { ... }
Best regards,
Mateusz Loskot
http://mateusz.loskot.net
More information about the Liblas-devel mailing list
