[Liblas-devel] Vertical Datum Transformation
Howard Butler hobu.inc at gmail.com
Mon Nov 1 22:07:17 EDT 2010
Ibraheem,
I have placed the file in the liblas.org sample library at <http://liblas.org/samples/galveston_EPSG_32615_4326.las>.  If it is not ok for this file to be on a public download, please let me know and I'll remove it quickly. Otherwise, it in combination with all of the email traffic should provide someone some good examples to start playing around with these types of operations.
The root of the problem is what Frank described in his earlier email <http://lists.osgeo.org/pipermail/liblas-devel/2010-November/001029.html>, and I will refresh the libLAS packages on OSGeo4W to take advantage of these changes in the next couple of days.  Expect 1.6.0b2 very soon.
Thank you for the bug reports and testing!
Howard
>   Header Summary
>   Version:                     1.2
>   Source ID:                   0
>   Reserved:                    0
>   Project ID/GUID:             '00000000-0000-0000-0000-000000000000'
>   System ID:                   ''
>   Generating Software:         'TerraScan'
>   File Creation Day/Year:      0/0
>   Header Byte Size             227
>   Data Offset:                 485
>   Number Var. Length Records:  2
>   Point Data Format:           1
>   Number of Point Records:     99660
>   Number of Points by Return:  99658 2 0 0 0
>   Scale Factor X Y Z:          0.01 0.01 0.01
>   Offset X Y Z:                -0.00 -0.00 -0.00
>   Min X Y Z:                   293658.50 3219000.00 -0.54
>   Max X Y Z:                   293999.99 3219406.93 7.67
>   Spatial Reference:
> PROJCS["WGS 84 / UTM zone 15N",
>     GEOGCS["WGS 84",
>         DATUM["WGS_1984",
>             SPHEROID["WGS 84",6378137,298.257223563,
>                 AUTHORITY["EPSG","7030"]],
>             AUTHORITY["EPSG","6326"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4326"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",-93],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","32615"]]
> Geotiff_Information:
>    Version: 1
>    Key_Revision: 1.0
>    Tagged_Information:
>       End_Of_Tags.
>    Keyed_Information:
>       GTModelTypeGeoKey (Short,1): ModelTypeProjected
>       GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
>       GTCitationGeoKey (Ascii,32): "WGS 84 / UTM zone 15N + VERT_CS"
>       GeogCitationGeoKey (Ascii,7): "WGS 84"
>       GeogAngularUnitsGeoKey (Short,1): Angular_Degree
>       ProjectedCSTypeGeoKey (Short,1): PCS_WGS84_UTM_zone_15N
>       ProjLinearUnitsGeoKey (Short,1): Linear_Meter
>       VerticalCSTypeGeoKey (Short,1): Unknown-5703
>       VerticalCitationGeoKey (Ascii,14): "NAVD88 height"
>       VerticalDatumGeoKey (Short,1): Unknown-5103
>       VerticalUnitsGeoKey (Short,1): Linear_Meter
>       End_Of_Keys.
>    End_Of_Geotiff.
>   VLR Summary
>     User: 'LASF_Projection' - Description: ''
>     ID: 34735 Length: 96
>     ID: 34737 Length: 54
>   Schema Summary
>   Point Format ID:             1
>   Number of dimensions:        13
>   Custom schema?:              false
>   Size in bytes:               28
>   Dimensions
>   'X' --  size: 32 offset: 0
>   'Y' --  size: 32 offset: 4
>   'Z' --  size: 32 offset: 8
>   'Intensity' --  size: 16 offset: 12
>   'Return Number' --  size: 3 offset: 14
>   'Number of Returns' --  size: 3 offset: 14
>   'Scan Direction' --  size: 1 offset: 14
>   'Flightline Edge' --  size: 1 offset: 14
>   'Classification' --  size: 8 offset: 15
>   'Scan Angle Rank' --  size: 8 offset: 16
>   'User Data' --  size: 8 offset: 17
>   'Point Source ID' --  size: 16 offset: 18
>   'Time' --  size: 64 offset: 20
>   Point Inspection Summary
>   Header Point Count: 99660
>   Actual Point Count: 99660
>   Minimum and Maximum Attributes (min,max)
>   Min X, Y, Z:          293658.50, 3219000.00, -0.54,
>   Max X, Y, Z:          293999.99, 3219406.93, 7.67,
>   Bounding Box:         293658.50, 3219000.00, 293999.99, 3219406.93
>   Time:                 516028.982201, 516037.190176
>   Return Number:        1, 2
>   Return Count:         1, 2
>   Flightline Edge:      0, 1
>   Intensity:            3, 351
>   Scan Direction Flag:  0, 1
>   Scan Angle Rank:      -2, 26
>   Classification:       1, 9
>   Point Source Id:      7, 7
>   User Data:            32, 32
>   Minimum Color:        0 0 0
>   Maximum Color:        0 0 0
>         (1) 99658       (2) 2
>   Number of Returns by Pulse
>         (1) 99656       (2) 4
>   Point Classifications
>         59966 Unclassified (1)
>         39665 Ground (2)
>         6 High Vegetation (5)
>         3 Low Point (noise) (7)
>         20 Water (9)
>         0 withheld
>         0 keypoint
>         0 synthetic
More information about the Liblas-devel mailing list
