[Liblas-devel] libgeotiff / cpl / libspatialreference.hpp changes
Julien Malik julien.malik at c-s.fr
Mon Nov 15 11:57:23 EST 2010
Hello,
I confirm it fixes the problem on my platform (ubuntu 10.10 - gcc 4.5 -
gdal 1.7.2 - geotiff 1.2.5)
Thanks
Julien
Le 15/11/2010 17:44, Frank Warmerdam a écrit :
> Frank Warmerdam wrote:
>> Julien Malik wrote:
>>> Hello,
>>> I encountered this bug, as did a lot of OrfeoToolbox users since we
>>> updated to liblas 1.6.0b2.
>>> It affects at least Ubuntu 10.04, 10.10, OpenSuse 11.2, 11.3 and
>>> OpenBSD 4.8+
>>> I personnally use ubuntu 10.10 with gdal/geotiff from
>>> ubuntugis/unstable repo, which gives me recent versions (gdal 1.7.2
>>> and geotiff 1.2.5), and it still does not work.
>> Julien,
>> Note that while these are reasonably recent, they are not current.
>>> So currently, gdal/geotiff support in liblas seems broken. I tested
>>> with yesterday's trunk.
>>> Just wanted to know if this problem will be addressed before the
>>> next release ?
>>> Or you will rely on the end-user to hand-modify a geotiff header
>>> (which he may not have access to) ?
>> I will investigate if there is a cleaner mechanism of handling this
>> issue.  Would you like to file a ticket with liblas's trac on the
>> problem so we can keep track of progress?
>> Best regards,
> Julien and others,
> I have made a change in liblas trunk such that updating to the very
> newest
> libgeotiff or hand editing of geo_simpletags.h should no longer be
> necessary.  The changes are documented at:
>   http://trac.liblas.org/ticket/194
> In the longer term I'd like to strip some of the libgeotiff and gdal
> includes out of libspatialreference.hpp so we don't have such widespread
> interaction of environments.   But I'm not sure this is the right time to
> do that.
> Best regards,
More information about the Liblas-devel mailing list
