[Liblas-devel] Building under VS2010
Mateusz Loskot
mateusz at loskot.net
Fri Nov 19 19:36:38 EST 2010
On 20/11/10 00:30, Michael Gerlek wrote:
> (3) Make sure your include paths reference the osgeo4w gdal-dev
> include world first, and then the regular osgeo4w include world. This
> will solve your problems with SetEquirectangular2. Do the same for
> your library paths too, just in case.
I'd also suggest to have only gdal-dev installed.
> (5) You only need to download the Boost libraries for serialization
> and program-options -- none of the other libs. Really. And in
> theory, you need to only pull down the multithreaded/static versions,
> but I wound up bringing down all the versions before I was done.
I'd add, this is the recommended version for Windows users:
http://www.boostpro.com/download/
and remember to grab the one for VS2010
> If I was daring, I would now blow away my build environment and try
> again from scratch, and see if any of the above is *really* needed.
It's quite complete, I think.
> As my father always used to say, "It's easy, when you know how."
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
More information about the Liblas-devel
