[Liblas-devel] Building under VS2010
Mateusz Loskot mateusz at loskot.net
Sun Nov 21 19:47:26 EST 2010
On 20/11/10 20:28, Howard Butler wrote:
>> (3) Make sure your include paths reference the osgeo4w gdal-dev
>> include world first, and then the regular osgeo4w include world.
>> This will solve your problems with SetEquirectangular2.  Do the
>> same for your library paths too, just in case.
> Mateusz,
> I have commented out the test for SetEquirectangular2 for now.  It
> seems that check_function_exists can fail sometimes even though it
> shouldn't, and when it does, it doesn't give us an error message that
> is very helpful.
I haven't experienced it, so I can't tell.
> If someone compiles against an old GDAL, they're
> going to get an error we can more easily recognize and diagnose.
> Make sense?
It's always possible to make use of gdal-config to query version number
and compare against the minimum required version.
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
More information about the Liblas-devel mailing list
