[Liblas-devel] tackling the root of inefficiency,
with Parallel Python, LAStools
tisham at eleceng.adelaide.edu.au
Sun Apr 17 19:44:31 EDT 2011
Hi Aaron,
Python does make it simple but you are not really using interprocess
communication, I wrote some MPI based code to perform spatial filtering on
Lidar data. It may be of interest to you for performance testing -
https://code.google.com/p/lasmpi/
Cheers,
Tisham.
> OK, sorry for the cross post with the LAStools mailing list, but I thought
> this was kind of important. Not directly liblas, but close enough.
> All,
> been so busy as of late with a new job that I haven't had time to post
> this
> simple combination of parallel python and LAStools. Wrote it on a plane to
> germany, so it only is set to SMP, but it could easily be dumped across a
> system with several hundred nodes. Ah, I love python.
> import pp, time
> # Import system modules
> import sys, string, os
> def text_blaster(s):
> com = "C:/OSGeo4W/bin/las2txt.exe -i C:/projects/SB/input/SBEX_41.las
> -o
> C:/projects/SB/output/" + s
> app_run = str(com)
> z = os.system(app_run)
> my_list = ["SBEX_41.txt", "SBEX_41_2.txt", "SBEX_41_3.txt",
> "SBEX_41_4.txt",
> "SBEX_41_5.txt", "SBEX_41_6.txt", "SBEX_41_7.txt", "SBEX_41_8.txt",]
> print """Usage: python test_SMP.py [ncpus]
> [ncpus] - the number of workers to run in parallel,
> if omitted it will be set to the number of processors in the system
> # tuple of all parallel python servers to connect with
> ppservers = ("*",)
> if len(sys.argv) > 1:
> ncpus = int(sys.argv[1])
> # Creates jobserver with ncpus workers
> job_server = pp.Server(ncpus, ppservers=ppservers)
> else:
> # Creates jobserver with automatically detected number of workers
> job_server = pp.Server(ppservers=ppservers)
> start_time = time.time()
> print "Starting pp with", job_server.get_ncpus(), "workers"
> for process in my_list:
> job1 = job_server.submit(text_blaster, (process,))
> print "Time elapsed: ", time.time() - start_time, "s"
> result = job1()
> #print "CLUSTER TEST is", result
> # Submitted jobs and retrieved results
> job_server.print_stats()
> RESULTS:-------------------------------------------------------------------------------------------------------------------------------
> Starting pp with 1 workers
> Time elapsed: 0.00399994850159 s
> Time elapsed: 60.1719999313 s
> Job execution statistics:
> job count | % of all jobs | job time sum | time per job | job server
> 8 | 100.00 | 60.1650 | 7.520625 | local
> Time elapsed since server creation 60.1719999313
> Starting pp with 4 workers
> Time elapsed: 0.00999999046326 s
> Time elapsed: 27.8439998627 s
> 8 | 100.00 | 82.2060 | 10.275750 | local
> Time elapsed since server creation 27.8459999561
> Used one las file, 500 meters by 500 meters, 30pts per square meter. Time
> was cut in half. Well, less than half.
> Cheers,
> Aaron
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
