[Liblas-devel] cannot get tutorial example to compile
Stanley Wong
s.wong at kucerainternational.com
Fri Apr 29 18:14:42 EDT 2011
I am a beginner using VC++ Express 2010 on Windows 7.
I am starting with the C++ Tutorial (http://liblas.org/tutorial/cpp.html) but cannot get it to compile.
The error is:
testLibLas1.obj : error LNK2019: unresolved external symbol "public: unsigned int __thiscall liblas::Header::GetPointRecordsCount(void)const " (?GetPointRecordsCount at Header@liblas@@QBEIXZ) referenced in function _wmain
1>X:\Vector Edit\Users\stan\prog\c++\testLibLas1\Debug\testLibLas1.exe : fatal error LNK1120: 1 unresolved externals
I installed liblas through OSGeo4W, and built Boost using what's suggested (run bootstrap.bat then bjam.exe).
In VC++, I added the following:
C/C++ > General > additional Include Directories: C:\OSGeo4W\include;C:\Program Files (x86)\boost\boost_1_46_1
Linker > General > additional library directories: C:\OSGeo4W\lib;C:\Program Files (x86)\boost\boost_1_46_1\stage\lib
Linker > Input > Additional Dependencies: liblas.lib
Can anyone suggest what I am missing here?
Thanks.
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110429/82de002e/attachment.html
More information about the Liblas-devel
