[Liblas-devel] Written file can't be read by other .las viewers
James Hargrave
jhargrave at photomodeler.com
Fri Aug 26 15:39:16 EDT 2011
Hey guys,
Thanks for the suggestions and help. Running the repair gave me the clue I
needed. I wasn't setting the min/max values to the header.
Here's the output from the repair:
reporting all LAS header entries:
file signature: 'LASF'
file source ID: 0
reserved (global_encoding):0
project ID GUID data 1-4: 0 0 0 ''
version major.minor: 1.2
system identifier: 'libLAS'
generating software: 'libLAS 1.7.0b2'
file creation day/year: 237/2011
header size 227
offset to point data 227
number var. length records 0
point data format 3
point data record length 34
number of point records 5857
number of points by return 0 0 0 0 0
scale factor x y z 0.01 0.01 0.01
offset x y z 0 0 0
min x y z 0.00 0.00 0.00
max x y z 0.00 0.00 0.00
reporting minimum and maximum for all LAS point record entries ...
x -1323 1581
y -831 983
z -3855 -1905
intensity 0 0
edge_of_flight_line 0 0
scan_direction_flag 0 0
number_of_returns_of_given_pulse 0 0
return_number 0 0
classification 0 0
scan_angle_rank 0 0
user_data 0 0
point_source_ID 0 0
gps_time 0.000000 0.000000
Color R 0 220
G 1 243
B 0 255
WARNING: there are 5857 points with return number 0
WARNING: there are 5857 points with a number of returns of given pulse of 0
histogram of classification of points:
5857 Created, never classified (0)
real max x larger than header max x by 15.810000 (repaired)
real min x smaller than header min x by 13.230000 (repaired)
real max y larger than header max y by 9.830000 (repaired)
real min y smaller than header min y by 8.310000 (repaired)
real min z smaller than header min z by 38.550000 (repaired)
I added these lines after writing all the points (and computing the min/max
during the write):
header.SetMin( min.X(), min.Y(), min.Z() );
header.SetMax( max.X(), max.Y(), max.Z() );
writer->SetHeader(header);
writer->WriteHeader();
This fixed the problem.
Are there any other fields I should be specifically setting?
Heaps of thanks,
- James
> -----Original Message-----
> From: Howard Butler [mailto:hobu.inc at gmail.com]
> Sent: August-26-11 6:33 AM
> To: James Hargrave
> Cc: liblas-devel
> Subject: Re: [Liblas-devel] Written file can't be read by other .las
> viewers
> On Aug 26, 2011, at 8:11 AM, Howard Butler wrote:
> > On Aug 25, 2011, at 6:16 PM, James Hargrave wrote:
> >> Hello,
> >> When I use laslib to create a file I am able to then read the file back
> in
> >> and everything seems fine. However, I am unable to view the file in
> other
> >> applications such as the lasview.exe utility found here:
> >> http://www.cs.unc.edu/~isenburg/lastools/
> >> The steps I use mirror the C++ tutorial from the laslib.org site:
> >> ofs.open((char*)filename, ios::out | ios::binary);
> >> liblas::Header header;
> >> writer = new liblas::Writer(ofs, header);
> >> Then in a loop:
> >> liblas::Point point;
> >> point.SetCoordinates(pt.X(), pt.Y(), pt.Z());
> >> // fill other properties of point record
> >> if ( rgb )
> >> point.SetColor( liblas::Color( rgb[0], rgb[1], rgb[2] ) );
> >> writer->WritePoint(point);
> >> If anyone has any ideas I'd appreciate any suggestions. If it would
> help I
> >> can also provide a sample output file which I am able to read back in
> using
> >> liblas but does not appear when loaded into lasview.exe .
> >> Thanks,
> >> - James
> > James,
> > Which version of libLAS are you using? The following just worked for me
> this morning with the latest git HEAD on https://github.com/libLAS/libLAS
> > ~/liblas$ las2las TO_core_last_zoom.las lastools-test-from-liblas.las
> > ~/lastools/bin/lasinfo lastools-test-from-liblas.las
> >> file source ID: 0
> >> version major.minor: 1.0
> >> system identifier: ''
> >> generating software: 'TerraScan'
> >> file creation day/year: 0/0
> >> header size 227
> >> offset to point data 229
> >> point data format 1
> >> point data record length 28
> >> number of point records 213093
> >> number of points by return 128621 84472 0 0 0
> >> offset x y z -0 -0 -0
> >> min x y z 630250.00 4834500.00 46.83
> >> max x y z 630500.00 4834750.00 170.65
> >> the header is followed by 2 user-defined bytes
> >> x 63025000 63050000
> >> y 483450000 483475000
> >> z 4683 17065
> >> intensity 10 50200
> >> number_of_returns_of_given_pulse 1 2
> >> return_number 1 2
> >> classification 1 1
> >> scan_angle_rank 0 0
> >> user_data 2 4
> >> point_source_ID 0 0
> >> gps_time 413162.560400 414095.322000
> >> overview over number of returns of given pulse: 128621 84472 0 0 0 0 0
> >> 213093 Unclassified (1)
> > Are you making sure to delete the writer in your code? You must delete
> the writer because it will be writing header details at the end of
writing.
> Also, make sure to do ofs.close() to force the flush of any data left in
> the ostream buffer.
> After some discussion on IRC with Martin, he suggested you run the
> following:
> ~/lastools $ lasinfo -repair file-written-by-liblas.las
> I don't think your code is updating the header's bounds and return count
> information, and this might be required for lasview.exe to run.
> Howard
More information about the Liblas-devel
