[Liblas-devel] lasinfo: error while loading shared libraries
Volker Wichmann wichmann at laserdata.at
Sat Feb 19 11:59:24 EST 2011
Hi Eric,
did you run /sbin/ldconfig in order to configure dynamic linker run time
bindings?
Best regards,
Volker
On 02/19/2011 05:50 PM, Eric Goddard wrote:
> Hello everyone,
> I am trying to load some lidar data with grass/QGIS. Following the
> compilation instructions at http://liblas.org/compilation.html, I have
> successfully compiled and installed LibLAS1.6.0 on Linux Mint 10 (Ubuntu
> 10.10) with GDAL support to /usr/local.
> whenever I run
>       lasinfo -c ~/Downloads/S1980745.las
> I get the following error message:
> lasinfo: error while loading shared libraries: liblas.so.2.0.0: cannot
> open shared object file: No such file or directory
> This error occurs when running any of the las* tools, though
> liblas-config will correctly output its version.
> My /usr/local/lib directory contains the following liblas related files:
> liblas_c.so        liblas.so
> liblas_c.so.2.0.0  liblas.so.2.0.0
> so I am not sure why is saying that it cannot find the files.
> Any insight into this issue would be greatly appreciated.
> Thanks,
> Eric
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
