[Liblas-devel] Re: [otb-developers] small compilation fix
    Howard Butler
    hobu.inc at gmail.com
    Mon Jan 17 23:38:41 EST 2011
Amit,
Please file a ticket so this doesn't get lost.
http://trac.liblas.org
I see no reason why this couldn't be applied.
Howard
On Jan 17, 2011, at 6:03 PM, Amit Kulkarni wrote:
> Hi,
> Can somebody please consider this patch for inclusion?
> Thanks
> ---------- Forwarded message ----------
> From: Emmanuel Christophe <emmanuel.christophe at gmail.com>
> Date: Mon, Jan 17, 2011 at 5:41 PM
> Subject: Re: [otb-developers] small compilation fix
> To: otb-developers at googlegroups.com
> Hi Amit,
> Is it a patch that's already in liblas?
> On Mon, Jan 17, 2011 at 15:18, Amit Kulkarni <amitkulz at gmail.com> wrote:
>> Hi,
>> The below diff fixes the usage of LIBLAS_SWAP_BYTES_N in
>> indexoutput.hpp to be more consistent with other usages in files
>> lasindex.hpp and in private_utility.hpp.
>> This fixes a compilation error on OpenBSD 4.9beta with gcc 4.2.1
>> lvalue required as unary '&' operand for LIBLAS_SWAP_BYTES_N in indexoutput.hpp
>> Is it ok to commit?
>> Thanks,
>> amit
>> diff -r f1903272130b
>> Utilities/otbliblas/include/liblas/detail/index/indexoutput.hpp
>> --- a/Utilities/otbliblas/include/liblas/detail/index/indexoutput.hpp
>>  Mon Jan 17 13:49:12 2011 -0800
>> +++ b/Utilities/otbliblas/include/liblas/detail/index/indexoutput.hpp
>>  Mon Jan 17 17:03:25 2011 -0600
>> @@ -71,10 +71,10 @@
>>  template <typename T, typename Q>
>> -inline void WriteVLRData_n(IndexVLRData& dest, T src, Q& pos)
>> +inline void WriteVLRData_n(IndexVLRData& dest, T& src, Q& pos)
>>     // Fix little-endian
>> -    LIBLAS_SWAP_BYTES_N(&src, sizeof(T));
>> +    LIBLAS_SWAP_BYTES_N(src, sizeof(T));
>>     // error if writing past array end
>>     if (static_cast<size_t>(pos) + sizeof(T) > dest.size())
>>                throw
>> std::out_of_range("liblas::detail::WriteVLRData_n: array index out of
>> range");
>> @@ -85,10 +85,10 @@
>> -inline void WriteVLRDataNoInc_n(IndexVLRData& dest, T src, Q const& pos)
>> +inline void WriteVLRDataNoInc_n(IndexVLRData& dest, T& src, Q const& pos)
>>                throw
>> std::out_of_range("liblas::detail::WriteVLRDataNoInc_n: array index
>> out of range");
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
