[Liblas-devel] Python memory usage issue
Nicola Creati ncreati at inogs.it
Fri Jan 21 05:07:52 EST 2011
Hello,
running this simple Python script you will find that you will soon get
out of memory. (It works with any las files)
Can someone explain why?
Thanks,
Nicola
from liblas.file import File
f = File('/Downloads/libLAS-1.6.0b3/test/data/1.1_1.las')
for i in xrange(15000):
     temp = f.header.offset
Nicola Creati
Istituto Nazionale di Oceanografia e di Geofisica Sperimentale - OGS www.inogs.it Dipartimento di Geofisica della Litosfera Geophysics of Lithosphere Department CARS (Cartography and Remote Sensing) Research Group http://www.inogs.it/Cars/ Borgo Grotta Gigante 42/c 34010 Sgonico - Trieste - ITALY ncreati at ogs.trieste.it
off.   +39 040 2140 213
fax.   +39 040 327307
_____________________________________________________________________
This communication, that may contain confidential and/or legally privileged information, is intended solely for the use of the intended addressees. Opinions, conclusions and other information contained in this message, that do not relate to the official business of OGS, shall be considered as not given or endorsed by it. Every opinion or advice contained in this communication is subject to the terms and conditions provided by the agreement governing the engagement with such a client. Any use, disclosure, copying or distribution of the contents of this communication by a not-intended recipient or in violation of the purposes of this communication is strictly prohibited and may be unlawful. For Italy only: Ai sensi del D.Lgs.196/2003 - "T.U. sulla Privacy" si precisa che le informazioni contenute in questo messaggio sono riservate ed a uso esclusivo del destinatario.
More information about the Liblas-devel mailing list
