[Liblas-devel] pass a memory map pointer to uchar to lasreader
francesco
francesco.pirotti at unipd.it
Thu Jul 21 13:12:12 EDT 2011
Hello,
I am using Qt SDK for explicit run-time linking to LIBLAS liblas_c.dll .
Because Qt supports memory mapping of files (maps a file to a unsigned
char *) my idea was to pass a file map to create the reader instead of
passing the file name. I therefore cloned the Create_reader function to
the function at the end of this mail.
The error message from GetLastErrorMsg is always _detail::liblas::read_n
input stream is not readable_
So two questions to the list:
1 - do you think memory mapping can be a good solution to speed up
processing data??
2 - Am I doing something obviously wrong??
Thank you for your time and effort.
Cheers,
Francesco Pirotti
in *liblas.h*
typedefconstLASReaderHLASReader_Create_mapped(unsignedchar*buffer);
*in c_api.cpp*
LAS_DLL LASReaderH LASReader_Create_mapped(unsigned char * buffer)
VALIDATE_LAS_POINTER1(((char*)buffer), "LASReader_Create_mapped", NULL);
try {
std::istringstream * istrm = new std::istringstream((char *)buffer, std::ios::in | std::ios::binary);
liblas::ReaderFactory f;
liblas::Reader* reader = new liblas::Reader(f.CreateWithStream(*istrm));
readers.insert(std::pair<liblas::Reader*, std::istream*>(reader, istrm));
return (LASReaderH) reader;
} catch (std::exception const& e)
LASError_PushError(LE_Failure, e.what(), "LASReader_Create");
return NULL;
*Francesco Pirotti*
Dep. TESAF
CIRGEO -- Interdepartmental Research Center on Cartography Photogrammetry
Remote Sensing and G.I.S.
University of Padova
Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
Email: francesco.pirotti at unipd.it <mailto:francesco.pirotti at unipd.it>
Phone: +39 049 827 2710
Phone: +39 349 55 39 261
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110721/d3c5bcb0/attachment.html
More information about the Liblas-devel
