[Liblas-devel] Re: [GRASS-dev] grass7: problem --with-liblas
Doug_Newcomb at fws.gov Doug_Newcomb at fws.gov
Wed Jun 22 13:29:44 EDT 2011
Howard,
I'll try to look at it tonight.
Doug
Doug Newcomb
USFWS
Raleigh, NC
919-856-4520 ext. 14 doug_newcomb at fws.gov
The opinions I express are my own and are not representative of the
official policy of the U.S.Fish and Wildlife Service or Dept. of the
Interior.   Life is too short for undocumented, proprietary data formats.
Howard Butler <hobu.inc at gmail.com>
Sent by: liblas-devel-bounces at lists.osgeo.org
06/22/2011 12:57 PM
To
cc
Markus Metz <markus.metz.giswork at googlemail.com>,
grass-dev at lists.osgeo.org, liblas-devel at lists.osgeo.org
Subject
Re: [Liblas-devel] Re: [GRASS-dev] grass7: problem --with-liblas
Doug,
I think I have this one smashed. <http://trac.liblas.org/ticket/231> It
will be released in libLAS 1.7.0.  If you have the ability to pull down a
copy of the hg version <http://hg.liblas.org/main/archive/tip.tar.gz> and
test, I'd appreciate it.  Also, it should be much, much faster for
medium-to-large sized files.
Howard
On Jun 13, 2011, at 11:45 AM, Doug_Newcomb at fws.gov wrote:
> Hi Folks,
> Glynn's suggested hack to liblas-config  below  to work around the issue
in cmake allowed me to compile grass7 with liblas support over the weekend
on Ubuntu 11.04 x64.  I have not read any las files yet to see if it
actaully worked :-) , hopefully tonight I'll get a chance.
> Doug
> Doug Newcomb
> USFWS
> Raleigh, NC
> Sent by: grass-dev-bounces at lists.osgeo.org
> 06/01/2011 03:21 AM
> To
> Glynn Clements <glynn at gclements.plus.com>
> cc
> Martin Landa <landa.martin at gmail.com>, GRASS developers list
<liblas-devel at lists.osgeo.org>
> Subject
> On Tue, May 31, 2011 at 11:34 PM, Glynn Clements
> <glynn at gclements.plus.com> wrote:
> > Markus Metz wrote:
> >> Is this "optimized;" and ";debug;" now a problem of GRASS or of
libLAS?
> > libLAS. Although it / be an issue with CMake's FindBoost module
> > (search for "optimized" in FindBoost.cmake).
> This seems to be a bug in cmake 2.8.4, not present in cmake 2.8.2. I
> just updated cmake from 2.8.2 to 2.8.4 and now get the same problem.
> Or the syntax in liblas-config.in is wrong.
> I suggest to hack liblas-config and replace the offending line
> LIBS="-L$libdir -llas -llas_c -L/usr/lib
optimized;/usr/lib/libboost_program_options-mt-1_42.so;debug;/usr/lib/libboost_program_options-mt.so"
> with
> or
> LIBS="-L$libdir -llas -llas_c -L/usr/lib64
> /usr/lib64/libboost_program_options-mt.so"
> >> BTW, what version of libLAS are you using?
> > I'm using the libLAS-1.6.1 source package:
> >        $ ls -l libLAS-*
> >        -rw-r--r-- 1 glynn root 7817956 May 30 18:49
libLAS-1.6.1.tar.gz
> >        $ md5sum libLAS-*
> >        2ce4f36f267c2f25bfc99c3f00e9cbd3  libLAS-1.6.1.tar.gz
> grass-dev mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-dev
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110622/268e50a5/attachment.html
More information about the Liblas-devel mailing list
