[Liblas-devel] Ground Modeling with RAW LiDAR and libLAS
Stuart Edwards
sedwards2 at cinci.rr.com
Fri Mar 4 09:05:09 EST 2011
GRASS GIS (open source) has several modules for processing raw LiDAR data and the ability to script your own classification routines. LibLAS does a nice job of preprocessing (decoding) the LAS files so they can be input to GRASS as x,y,z or general ASCII format .......see:
http://grass.osgeo.org/wiki/LIDAR#Micro-tutorial
Stu
On Mar 4, 2011, at 1:31 AM, francesco wrote:
> Hello List,
> I just registered, hello to everyone.
> Regarding Aaron's question, I am playing around with LibLAS to develop a ground classification procedure. It uses Axellson's progressive triangulation of local minimum points - but I am also looking at other solutions. Does anyone have other interesting approaches in mind?
> Cheers,
> Francesco
> Francesco Pirotti
> Dep. TESAF
> CIRGEO – Interdepartmental Research Center on Cartography Photogrammetry
> Remote Sensing and G.I.S.
> University of Padova
> Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
> Email: francesco.pirotti at unipd.it
> Phone: +39 049 827 2710
> Phone: +39 349 55 39 261
> Il 04/03/2011 00:49, Aaron Reyna ha scritto:
>> Ah yes,
>> I'll try the MCC-LiDAR. Great, thanks for the suggestion!
>> Aaron
>> On Thu, Mar 3, 2011 at 3:09 PM, Peter Tittmann <pwtittmann at ucdavis.edu> wrote:
>> I've used MCC-Lidar http://sourceforge.net/apps/trac/mcclidar/ a little with marginal results. Not a great answer but something. TeraScan http://www.terrasolid.fi/en/products/terrascan is the elephant in that room.
>> Peter
>> On 03/03/2011 02:43 PM, Aaron Reyna wrote:
>>> This may be too broad of a question, but has anyone seen or heard of a way to do efficient ground modeling with libLAS? That is, take raw LiDAR files (all default points) and model out the ground class? I do have raw LiDAR files if it helps.
>>> Just throwing it out there.
>>> Best,
>>> Aaron
>>> Liblas-devel mailing list
>>> Liblas-devel at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/liblas-devel
>> Peter Tittmann
>> Geography Graduate Group
>> UC Davis
>> c. 707 849 4135
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110304/4a27b7b2/attachment.html
More information about the Liblas-devel
