[Liblas-devel] Ground Modeling with RAW LiDAR and libLAS
francesco
francesco.pirotti at unipd.it
Mon Mar 7 05:50:36 EST 2011
Definitively will check SAGA GIS out (I already downloaded it). I am
still trying to find the perfect GIS box ...
Cheers,
Francesco
Il 06/03/2011 20:07, Volker Wichmann ha scritto:
> SAGA GIS is also worth a look (http://www.saga-gis.org).
> It uses libLAS for LAS file import to the SAGA native point cloud
> format. SAGA includes several tools to manipulate the point cloud,
> e.g. an attribute calculator, reclassifier, subset extractor and many
> other methods like gridding and interpolation. There is also (a grid
> based) bare earth filter, adapted from Vosselman (2001).
> SAGA API is C++ and implementing own modules is quite straight forward.
> Volker
> On 03/04/2011 03:05 PM, Stuart Edwards wrote:
>> GRASS GIS (open source) has several modules for processing raw LiDAR
>> data and the ability to script your own classification routines. LibLAS
>> does a nice job of preprocessing (decoding) the LAS files so they can be
>> input to GRASS as x,y,z or general ASCII format .......see:
>> http://grass.osgeo.org/wiki/LIDAR#Micro-tutorial
>> Stu
>> On Mar 4, 2011, at 1:31 AM, francesco wrote:
>>> Hello List,
>>> I just registered, hello to everyone.
>>> Regarding Aaron's question, I am playing around with LibLAS to develop
>>> a ground classification procedure. It uses Axellson's progressive
>>> triangulation of local minimum points - but I am also looking at other
>>> solutions. Does anyone have other interesting approaches in mind?
>>> Cheers,
>>> Francesco
>>> *Francesco Pirotti*
>>> Dep. TESAF
>>> CIRGEO – Interdepartmental Research Center on Cartography
>>> Photogrammetry
>>> Remote Sensing and G.I.S.
>>> University of Padova
>>> Web: http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
>>> Email: francesco.pirotti at unipd.it <mailto:francesco.pirotti at unipd.it>
>>> Phone: +39 049 827 2710
>>> Phone: +39 349 55 39 261
>>> Il 04/03/2011 00:49, Aaron Reyna ha scritto:
>>>> Ah yes,
>>>> I'll try the MCC-LiDAR. Great, thanks for the suggestion!
>>>> Aaron
>>>> On Thu, Mar 3, 2011 at 3:09 PM, Peter Tittmann
>>>> <pwtittmann at ucdavis.edu <mailto:pwtittmann at ucdavis.edu>> wrote:
>>>> I've used MCC-Lidar http://sourceforge.net/apps/trac/mcclidar/ a
>>>> little with marginal results. Not a great answer but something.
>>>> TeraScan http://www.terrasolid.fi/en/products/terrascan is the
>>>> elephant in that room.
>>>> Peter
>>>> On 03/03/2011 02:43 PM, Aaron Reyna wrote:
>>>>> This may be too broad of a question, but has anyone seen or
>>>>> heard of a way to do efficient ground modeling with libLAS? That
>>>>> is, take raw LiDAR files (all default points) and model out the
>>>>> ground class? I do have raw LiDAR files if it helps.
>>>>> Just throwing it out there.
>>>>> Best,
>>>>> Aaron
>>>>> _______________________________________________
>>>>> Liblas-devel mailing list
>>>>> Liblas-devel at lists.osgeo.org
>>>>> <mailto:Liblas-devel at lists.osgeo.org>
>>>>> http://lists.osgeo.org/mailman/listinfo/liblas-devel
>>>> Peter Tittmann
>>>> Geography Graduate Group
>>>> UC Davis
>>>> c. 707 849 4135
*Francesco Pirotti*
Dep. TESAF
CIRGEO – Interdepartmental Research Center on Cartography Photogrammetry
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110307/101b9f3a/attachment.html
More information about the Liblas-devel
