[Liblas-devel] libLAS Compilation Error - LNK1120
unresolved externals
Philipp
games at philipp.info
Wed Nov 23 11:35:08 EST 2011
I'm using the latest sources:
libLAS-libLAS-1.7.0b2-30-g75501dd.zip
Strange thing :( ..
philipp
> This one looks familiar, I think I saw it a week or two ago... are you
> using the latest sources?
> -mpg
>> -----Original Message-----
>> From: liblas-devel-bounces at lists.osgeo.org
>> [mailto:liblas-devel-bounces at lists.osgeo.org] On Behalf Of Philipp
>> Sent: Wednesday, November 23, 2011 7:53 AM
>> To: liblas-devel at lists.osgeo.org
>> Subject: [Liblas-devel] libLAS Compilation Error - LNK1120 unresolved
>> externals
>> Hi all,
>> I want to compile libLAS with Visual Studio 2010 under Windows 7 (x86).
>> I've installed all the necessary dependencies (boost with all Variants,
>> OSGeo4W with gdal-devel, geotiff, oci, ...) and used the default
>> Directories to be as synchron as possible with the install-guide.
>> But I get this error all time:
>> Error 70 error LNK1120: 1 unresolved externals
>> C:\dev\libLAS\bin\Debug\liblas.dll liblas
>> Error 69 error LNK2019: unresolved external symbol
>> "public:
>> char const * __thiscall LASitem::get_name(void)const "
>> (?get_name at LASitem@@QBEPBDXZ) referenced in function "public: class
>> liblas::property_tree::basic_ptree<class std::basic_string<char,struct
>> std::char_traits<char>,class std::allocator<char> >,class
>> std::basic_string<char,struct std::char_traits<char>,class
>> std::allocator<char>>,struct std::less<class
>> std::char_traits<char>,class std::allocator<char> > > > __thiscall
>> liblas::Header::GetPTree(void)const "
>> (?GetPTree at Header@liblas@@QBE?AV?$basic_ptree at V?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@
>> @V12 at U?$less at V?$basic_string at DU?$char_traits at D@std@@V?$allocator at D@2@@std@@@2@@property_tree at 2@XZ)
>> C:\dev\libLAS\src\header.cpp.obj liblas
>> Any idea ?
>> Thanks for any help,
>> philipp
>> Liblas-devel mailing list
>> Liblas-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
