[Liblas-devel] GetClassification() et al.
Peder Axensten Peder.Axensten at slu.se
Wed Oct 26 09:25:35 EDT 2011
Great!
Then I don't do anything, the fixes are on their way?
/Peder
On 26 okt 2011, at 11:16, Mateusz Łoskot wrote:
> 2011/10/26 Peder Axensten <Peder.Axensten at slu.se>:
>>> I presented bug and fix here: https://gist.github.com/1313176
>> Should not the other two be fixed too:
>>        void Point::SetClassification(Classification::bitset_type const& flags) and
>>        void Point::SetClassification(boost::uint8_t const& flags)?
> Yes, they should.
>> Maybe a few unit tests using the various SetClassification(...) to check for this bug?
> Patches are welcome, I guess.
>> The only way to retrieve the uint8_t (m_data[15]) as a uint8_t is through conversion to unsigned long and back?
> Yes. This is because I decided to use std::bitset users convenience to
> be able to play with bit flags easier.
> LAS classification is not 1 byte, but it's 4 different kinds of
> information encoded in space of 1 byte
> in order to save some space. Main purpose of liblas::Classification is
> to represent the classification concept
> and attributes, but not its low-level implementation.
>> (By static_cast<boost::uint8_t>(bits.to_ulong()).)
> or syntax sugar of functional notation which is equivalent:
> boost::uint8_t(bits.to_ulong()))
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
> Member of ACCU, http://accu.org
More information about the Liblas-devel mailing list
