[Liblas-devel] [Dev c++] Linker error. problem with liblas
Angley, William [USA]
angley_william at bah.com
Thu Sep 8 20:05:45 EDT 2011
A quick glance at the site says that Dev-C++ uses the MinGW compilers.
Recalling a conversation from several months ago [1][2], I replied to Michal earlier today and said that the only supported compiler on Windows is the Visual C compiler.
Is that still the case, or are we able to use MinGW to build libLAS nowadays?
-- Will
[1] http://lists.osgeo.org/pipermail/liblas-devel/2010-December/001101.html
[2] http://lists.osgeo.org/pipermail/liblas-devel/2010-December/001103.html
-----Original Message-----
From: liblas-devel-bounces at lists.osgeo.org [mailto:liblas-devel-bounces at lists.osgeo.org] On Behalf Of Michael Gerlek
Sent: Thursday, September 08, 2011 7:49 PM
To: Mateusz Loskot
Cc: miraat at poczta.onet.pl; liblas-devel
Subject: Re: [Liblas-devel] [Dev c++] Linker error. problem with liblas
Oh, mingw... Sorry, just ignore me.
.mpg
On Sep 8, 2011, at 4:40 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 09/09/11 00:30, Michael P. Gerlek wrote:
>> Michal:
>> Does "Dev C++" mean Microsoft Visual Studio?
> I assumed he means this
> http://www.bloodshed.net/devcpp.html
>> If so, you actually need the liblas.dll file, not liblas.a (that
>> would be for unix) -- these files are on the osgeo4w distribution now, I think.
> For Visual C++, you need liblas.dll and the import library liblas.lib.
> AFAIK, the Dev C++ is GCC-based, so it needs similar approach as
> MinGW, means liblas.a.
> Cheers,
> Mateusz Loskot, http://mateusz.loskot.net Charter Member of OSGeo,
> http://osgeo.org Member of ACCU, http://accu.org
Liblas-devel mailing list
Liblas-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
