[Liblas-devel] Can Liblas only update a small portion of the points in Lidar file?
Hongwei Shen henryshen.cn at gmail.com
Fri Feb 10 14:25:14 EST 2012
Howard and Martin,
Thank you for the answers and suggestions.
I'll go ahead to implement the code and disable it for LAZ files.
Hongwei
On Fri, Feb 10, 2012 at 12:15 PM, Howard Butler <hobu.inc at gmail.com> wrote:
> On Feb 10, 2012, at 11:10 AM, Martin Isenburg wrote:
> > Hi,
> > Make sure you disable the feature when the file is laszipped. There is
> > *no* way to add this. However, we could - in theory - support the
> > appending of points to an exsiting LAZ file.
> Yes, definitely.  The "Update" class will not be able to have LASzip-based
> data underneath it.
> Howard
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20120210/c2278caa/attachment.html
More information about the Liblas-devel mailing list
