[Liblas-devel] Can Liblas only update a small portion of the
points in Lidar file?
Hongwei Shen
henryshen.cn at gmail.com
Fri Jan 6 15:36:31 EST 2012
Thank you for the answer, Howard.
I'll check if I can add this support.
Thanks,
Hongwei
On Fri, Jan 6, 2012 at 1:47 PM, Howard Butler <hobu.inc at gmail.com> wrote:
> On Jan 6, 2012, at 12:16 PM, Hongwei Shen wrote:
>> Hello,
>> The scenario is: the user opens a large Lidar file, changes the
>> classification labels of a small number of points and save the changes
>> to the file. When the Lidar file is huge, it is time-consuming to
>> output all the points. So it would be better if only the modified
>> points are updated in the Lidar file. According to my understanding
>> now, Liblas needs to save all the (changed and unchanged) points to a
>> new Lidar file. That's because Liblas can open a Lidar file either in
>> read-only mode or write-only mode, but not in read-write mode.
>> Do I understand correctly? Is there a way to only update some points?
> Yes, your understanding is correct. libLAS does not support in-place updating of points.
> Howard
More information about the Liblas-devel
