[Liblas-devel] Re: GetProj4() string and NAD83
Adam Stylinski
stylinae at mail.uc.edu
Tue Jan 10 13:56:49 EST 2012
On Tue, Jan 10, 2012 at 1:25 PM, Howard Butler <hobu.inc at gmail.com> wrote:
> and LAStools now does vertical datum transformations too? If so, even more
> reason to not use libLAS :)
> On Jan 10, 2012, at 12:10 PM, Martin Isenburg wrote:
> > Hi,
> > when debugging GDAL it may help to look at what LASlib's
> > geoprojectionconverter does, which finds that the file
> > "IowaDNR-CloudPeakSoft-1.0-UTM15N.las" has correct GeoTIFFs . When I
> > create an intensity grid with
> > lasgrid -i IowaDNR-CloudPeakSoft-1.0-UTM15N.las -intensity -opng -step 3
> > the generated intensity raster is automatically geo-referenced and a
> > corresponding KML file is generated that places the PNG onto Google
> > Earth at the exact right spot as you can see here:
> > http://lastools.org/download/data/IowaDNR-CloudPeakSoft-1.0-UTM15N.kmz
> > Cheers,
> > Martin @lastools
> > PS: below is the report of lasinfo -i
> > reporting all LAS header entries:
> > file signature: 'LASF'
> > file source ID: 0
> > global_encoding: 0
> > project ID GUID data 1-4: 0 0 0 ''
> > version major.minor: 1.0
> > system identifier: ''
> > generating software: 'CPS/RTW LAS Lib v1.08'
> > file creation day/year: 0/0
> > header size 227
> > offset to point data 639
> > number var. length records 3
> > point data format 1
> > point data record length 28
> > number of point records 5847380
> > number of points by return 2920986 2926394 0 0 0
> > scale factor x y z 0.001 0.001 0.001
> > offset x y z 0 4000000 0
> > min x y z 614000.000 4791999.999 311.676
> > max x y z 615999.990 4793999.989 398.959
> > variable length header record 1 of 3:
> > reserved 43707
> > user ID 'LASF_Projection'
> > record ID 34735
> > length after header 88
> > description 'Projection Info'
> > GeoKeyDirectoryTag version 1.1.0 number of keys 10
> > key 1024 tiff_tag_location 0 count 1 value_offset 1 -
> > GTModelTypeGeoKey: ModelTypeProjected
> > key 1026 tiff_tag_location 34737 count 13 value_offset 0 -
> > GTCitationGeoKey: UTM zone 15N
> > key 2050 tiff_tag_location 0 count 1 value_offset 6269 -
> > GeogGeodeticDatumGeoKey: Datum_North_American_Datum_1983
> > key 2056 tiff_tag_location 0 count 1 value_offset 7019 -
> > GeogEllipsoidGeoKey: Ellipse_GRS_1980
> > key 3072 tiff_tag_location 0 count 1 value_offset 26915 -
> > ProjectedCSTypeGeoKey: PCS_NAD83_UTM_zone_15N
> > key 3075 tiff_tag_location 0 count 1 value_offset 1 -
> > ProjCoordTransGeoKey: CT_TransverseMercator
> > key 3076 tiff_tag_location 0 count 1 value_offset 9001 -
> > ProjLinearUnitsGeoKey: Linear_Meter
> > key 4096 tiff_tag_location 0 count 1 value_offset 5103 -
> > VerticalCSTypeGeoKey: VertCS_North_American_Vertical_Datum_1988
> > key 4097 tiff_tag_location 34737 count 19 value_offset 13 -
> > VerticalCitationGeoKey: GEOID 2003 Applied
> > key 4099 tiff_tag_location 0 count 1 value_offset 9001 -
> > VerticalUnitsGeoKey: Linear_Meter
> > variable length header record 2 of 3:
> > reserved 43707
> > record ID 34737
> > length after header 32
> > GeoAsciiParamsTag (number of characters 32)
> > UTM zone 15N GEOID 2003 Applied
> > variable length header record 3 of 3:
> > reserved 43707
> > user ID 'CloudPeakSoft'
> > record ID 0
> > length after header 128
> > description 'CPSInfo'
> > the header is followed by 2 user-defined bytes
> > reporting minimum and maximum for all LAS point record entries ...
> > x 614000000 615999990
> > y 791999999 793999989
> > z 311676 398959
> > intensity 1 3240
> > edge_of_flight_line 0 0
> > scan_direction_flag 0 0
> > number_of_returns_of_given_pulse 2 2
> > return_number 1 2
> > classification 1 12
> > scan_angle_rank 0 0
> > user_data 0 0
> > point_source_ID 14 18
> > gps_time 597987.305116 600731.680834
> > overview over number of returns of given pulse: 0 5847380 0 0 0 0 0
> > histogram of classification of points:
> > 2762810 Unclassified (1)
> > 2156929 Ground (2)
> > 6318 Low Point (noise) (7)
> > 921323 Overlap Points (12)
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
I should probably mention that my proj.4 is built with datum grids as well.
Liblas is built with GDAL and geotiff as well.
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20120110/ff1d889c/attachment-0001.html
More information about the Liblas-devel
