[Liblas-devel] updating liblas dependencies to support EPSG:2966
Crosby, Christopher
ccrosby at sdsc.edu
Fri May 11 15:05:06 EDT 2012
Hi Everyone,
I just wanted to follow up on this inquiry from Charlie last week regarding using libLAS to assign coordinate information to a batch of LAS files. The dataset is in EPSG: 2966 (http://spatialreference.org/ref/epsg/2966/ - note spatialreference.org appears to be down at the moment ), but when libLAS is used to generate the VLRs it appears to be writing an incomplete definition (DATUM and SPHEROID are "unknown" / "unretrievable") and thus later operations such as projection fail.
Is this problem related to libLAS, or the underlying GDAL/proj4 libraries? Does anyone have a recommendation for a work around?
Thanks,
-Chris
On May 4, 2012, at 3:57 PM, Charles Cowart wrote:
> Hi Howard,
> We've recently tried to annotate a dataset with EPSG:2966+5703 and liblas inserts the following into the VLRs:
> LOCAL_CS["NAD83 / Indiana West (ftUS) + VERT_CS",
> GEOGCS["NAD83",
> DATUM["unknown",
> SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> AUTHORITY["EPSG","2966"],
> UNIT["US survey foot",0.3048006096012192]]
> Geotiff_Information:
> Version: 1
> Key_Revision: 1.0
> Tagged_Information:
> End_Of_Tags.
> Keyed_Information:
> GTModelTypeGeoKey (Short,1): ModelTypeProjected
> GTRasterTypeGeoKey (Short,1): RasterPixelIsArea
> GTCitationGeoKey (Ascii,38): "NAD83 / Indiana West (ftUS) + VERT_CS"
> GeogCitationGeoKey (Ascii,6): "NAD83"
> GeogAngularUnitsGeoKey (Short,1): Angular_Degree
> ProjectedCSTypeGeoKey (Short,1): Unknown-2966
> ProjLinearUnitsGeoKey (Short,1): Linear_Foot_US_Survey
> VerticalCSTypeGeoKey (Short,1): Unknown-5703
> VerticalCitationGeoKey (Ascii,14): "NAVD88 height"
> VerticalDatumGeoKey (Short,1): Unknown-5103
> VerticalUnitsGeoKey (Short,1): Linear_Meter
> End_Of_Keys.
> End_Of_Geotiff.
> This doesn't reflect what is listed in spatial reference.org (http://spatialreference.org/ref/epsg/2966/), and doesn't appear to be enough to reproject the data into other coordinates systems. Do you know if it's possible to insert the information found in spatial reference.org into proj so that it will insert VLR data like that found in the link?
> Best Regards,
> Charles
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
