[Liblas-devel] Issues with Linking
Charles Karney charles.karney at sri.com
Wed Jun 19 18:15:52 PDT 2013
I posted a patch to the cmake configuration to libLAS which put
the runtime library paths into the utilities.  It looks like the
patch never got applied?  I'll hunt down the E-mail which included
the patch...
   --Charles
On 06/19/2013 08:58 PM, Sean Baskin wrote:
> All of the tools included in lasLib cannot link to the dynamic
> libraries. Below is the workflow I followed:
> # Install Boost libraries
> sudo tar -xvzf boost_1_53_0.tar.gz -C /opt
> cd /opt/boost_1_53_0/
> sudo ./bootstrap.sh
> sudo ./b2
> # Install cmake
> sudo tar -xvzf cmake-2.8.11.1.tar.gz -C /opt
> cd /opt/cmake-2.8.11.1/
> sudo ./bootstrap
> sudo make && sudo make install
> #Install libLAS
> sudo tar -xf libLAS-1.7.0.tar.gz -C /opt/
> cd /opt/libLAS-1.7.0/
> sudo mkdir makefiles
> cd makefiles/
> sudo cmake -G "Unix Makefiles" -DBOOST_ROOT=/opt/boost_1_53_0 ../
> sudo make
> sudo make install
> Towards the end of the make install is this output
> Install the project...
> -- Install configuration: "Release"
> -- Installing: /usr/local/share/liblas/doc/AUTHORS
> -- Installing: /usr/local/share/liblas/doc/COPYING
> -- Installing: /usr/local/share/liblas/doc/INSTALL
> -- Installing: /usr/local/share/liblas/doc/LICENSE.txt
> -- Installing: /usr/local/share/liblas/doc/README.txt
> -- Installing: /usr/local/lib/liblas.so.2.2.0
> -- Removed runtime path from "/usr/local/lib/liblas.so.2.2.0"
> -- Installing: /usr/local/lib/liblas_c.so.2.2.0
> -- Removed runtime path from "/usr/local/lib/liblas_c.so.2.2.0"
> -- Installing: /usr/local/include/liblas
> -- Installing: /usr/local/include/liblas/writer.hpp
> -- Installing: /usr/local/include/liblas/filter.hpp
> -- Installing: /usr/local/include/liblas/spatialreference.hpp
> -- Installing: /usr/local/include/liblas/detail
> -- Installing: /usr/local/include/liblas/detail/private_utility.hpp
> -- Installing: /usr/local/include/liblas/detail/index
> -- Installing: /usr/local/include/liblas/detail/index/indexcell.hpp
> -- Installing: /usr/local/include/liblas/detail/index/indexoutput.hpp
> -- Installing: /usr/local/include/liblas/detail/pointrecord.hpp
> -- Installing: /usr/local/include/liblas/detail/sha1.hpp
> -- Installing: /usr/local/include/liblas/detail/timer.hpp
> -- Installing: /usr/local/include/liblas/detail/singleton.hpp
> -- Installing: /usr/local/include/liblas/detail/binary.hpp
> -- Installing: /usr/local/include/liblas/detail/fwd.hpp
> -- Installing: /usr/local/include/liblas/detail/opt_allocator.hpp
> -- Installing: /usr/local/include/liblas/detail/file_ptr_stream.hpp
> -- Installing: /usr/local/include/liblas/detail/zippoint.hpp
> -- Installing: /usr/local/include/liblas/detail/endian.hpp
> -- Installing: /usr/local/include/liblas/detail/writer
> -- Installing: /usr/local/include/liblas/detail/writer/writer.hpp
> -- Installing: /usr/local/include/liblas/detail/writer/zipwriter.hpp
> -- Installing: /usr/local/include/liblas/detail/writer/header.hpp
> -- Installing: /usr/local/include/liblas/detail/writer/point.hpp
> -- Installing: /usr/local/include/liblas/detail/reader
> -- Installing: /usr/local/include/liblas/detail/reader/zipreader.hpp
> -- Installing: /usr/local/include/liblas/detail/reader/header.hpp
> -- Installing: /usr/local/include/liblas/detail/reader/cachedreader.hpp
> -- Installing: /usr/local/include/liblas/detail/reader/reader.hpp
> -- Installing: /usr/local/include/liblas/index.hpp
> -- Installing: /usr/local/include/liblas/chipper.hpp
> -- Installing: /usr/local/include/liblas/utility.hpp
> -- Installing: /usr/local/include/liblas/dimension.hpp
> -- Installing: /usr/local/include/liblas/classification.hpp
> -- Installing: /usr/local/include/liblas/version.hpp
> -- Installing: /usr/local/include/liblas/header.hpp
> -- Installing: /usr/local/include/liblas/color.hpp
> -- Installing: /usr/local/include/liblas/guid.hpp
> -- Installing: /usr/local/include/liblas/liblas.hpp
> -- Installing: /usr/local/include/liblas/exception.hpp
> -- Installing: /usr/local/include/liblas/point.hpp
> -- Installing: /usr/local/include/liblas/reader.hpp
> -- Installing: /usr/local/include/liblas/bounds.hpp
> -- Installing: /usr/local/include/liblas/transform.hpp
> -- Installing: /usr/local/include/liblas/iterator.hpp
> -- Installing: /usr/local/include/liblas/external
> -- Installing: /usr/local/include/liblas/external/property_tree
> -- Installing:
> /usr/local/include/liblas/external/property_tree/ptree_fwd.hpp
> -- Installing: /usr/local/include/liblas/external/property_tree/detail
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/rapidxml.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/xml_parser_read_rapidxml.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/info_parser_write.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/info_parser_error.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/json_parser_read.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/xml_parser_error.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/ptree_implementation.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/xml_parser_writer_settings.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/file_parser_error.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/info_parser_read.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/json_parser_error.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/xml_parser_utils.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/ptree_utils.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/info_parser_writer_settings.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/json_parser_write.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/exception_implementation.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/info_parser_utils.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/xml_parser_write.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/detail/xml_parser_flags.hpp
> -- Installing: /usr/local/include/liblas/external/property_tree/ptree.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/ini_parser.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/exceptions.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/info_parser.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/json_parser.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/id_translator.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/ptree_serialization.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/string_path.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/xml_parser.hpp
> -- Installing:
> /usr/local/include/liblas/external/property_tree/stream_translator.hpp
> -- Installing: /usr/local/include/liblas/capi
> -- Installing: /usr/local/include/liblas/capi/las_config.h
> -- Installing: /usr/local/include/liblas/capi/las_version.h
> -- Installing: /usr/local/include/liblas/capi/liblas.h
> -- Installing: /usr/local/include/liblas/export.hpp
> -- Installing: /usr/local/include/liblas/compatibility.hpp
> -- Installing: /usr/local/include/liblas/error.hpp
> -- Installing: /usr/local/include/liblas/variablerecord.hpp
> -- Installing: /usr/local/include/liblas/schema.hpp
> -- Installing: /usr/local/include/liblas/factory.hpp
> -- Installing: /usr/local/bin/lasinfo-old
> -- Removed runtime path from "/usr/local/bin/lasinfo-old"
> -- Removed runtime path from "/usr/local/bin/lasinfo"
> -- Installing: /usr/local/bin/lasmerge
> -- Removed runtime path from "/usr/local/bin/lasmerge"
> -- Installing: /usr/local/bin/las2las
> -- Removed runtime path from "/usr/local/bin/las2las"
> -- Installing: /usr/local/bin/las2txt-old
> -- Removed runtime path from "/usr/local/bin/las2txt-old"
> -- Installing: /usr/local/bin/txt2las
> -- Removed runtime path from "/usr/local/bin/txt2las"
> -- Up-to-date: /usr/local/bin/las2las
> -- Installing: /usr/local/bin/las2las-old
> -- Removed runtime path from "/usr/local/bin/las2las-old"
> -- Installing: /usr/local/bin/lasblock
> -- Removed runtime path from "/usr/local/bin/lasblock"
> -- Installing: /usr/local/bin/ts2las
> -- Removed runtime path from "/usr/local/bin/ts2las"
> -- Removed runtime path from "/usr/local/bin/las2txt"
> -- Installing: /usr/local/bin/liblas-config
> When for example I try using lasinfo, the following error is returned:
> $ lasinfo 145E.las
> lasinfo: error while loading shared libraries: liblas.so.2.2.0: cannot
> open shared object file: No such file or directory
> Hope this helps. Thanks in advance.
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel mailing list
