[Liblas-devel] ECEF?
Frank Warmerdam
warmerdam at pobox.com
Mon Sep 9 11:00:50 PDT 2013
Keith,
I suspect the problem is that the EPSG catalogs are out of date in OSGeo4W.
Could you try the following and see if it works better?
las2las MyFile.las –a_srs "+proj=geocent +datum=WGS84 +units=m +no_defs"
–t_srs EPSG:2151
Best regards,
Frank
On Mon, Sep 9, 2013 at 10:29 AM, Keith Williams <keithw at unavco.org> wrote:
> Hello Frank,****
> I was hoping to request some assistance on converting a LiDAR point cloud
> from ECEF geocentric coordinates to UTM coordinates.****
> I noticed that you have previously discussed this at
> http://lists.osgeo.org/pipermail/liblas-devel/2011-March/001283.htmlhowever, I am quite new to Liblas, and command line interfaces in general
> so am not having much luck!****
> I am using: las2las MyFile.las –a_srs EPSG:4328 –t_srs EPSG:2151 through
> the OSGeo4W shell and I believe that I have the GDAL and liblas trunk files
> loaded; when installing the OSGeo4W shell I selected every GDAL and Liblas
> option available. I get the error that “ERROR 6: EPSG PCS/GCS code 4328
> not found in EPSG support files. Is this a valid EPSG coordinate system?
> error: could not import coordinate system into OSRSpatialReference
> SetFromUserInput”.****
> Thank you very much for any direction you may be willing to supply!****
> Keith****
> **Keith Williams, EIT, LSIT**
> UNAVCO, Inc.
> 6350 Nautilus Dr.
> Boulder, CO 80301***
> *Cell: (541) 224-2924***
> *keithw at unavco.org***
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | Geospatial Software Developer
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20130909/4c9980fb/attachment.html>
More information about the Liblas-devel
