[Liblas-devel] Georeferencing LAS files
Carlos Piury
dgpiury at gmail.com
Wed Jan 28 02:46:24 PST 2015
Hi, I am trying to add simple georeferecing information to my LAS files
with:
liblas::SpatialReference srs;
srs.SetFromUserInput("EPSG:4326");
header.SetSRS(srs);
But when I try to read it with lasinfo I get None:
Spatial Reference: None
If I print out the proj4 string it works well:
code: std::cout << srs.GetProj4() << endl;
output: +proj=longlat +datum=WGS84 +no_defs
However if I can read other las files not writed by me using lasinfo so I
think that the problem is in the code...
Thanks!
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20150128/0f08ebc1/attachment.html>
More information about the Liblas-devel
