[Liblas-devel] Build errors: version 1.8.1
Rich Shepard
rshepard at appl-ecosys.com
Mon Aug 29 12:49:30 PDT 2016
I'm trying to build libLAS-1.8.1 on Slackware-14.1. Make fails about 55%
toward completion with this error:
[ 55%] Building C object apps/CMakeFiles/las2col.dir/las2col.c.o
/opt/slackbuilds/GIS/libLAS/libLAS-1.8.1/apps/las2col.c: In function ‘main’:
/opt/slackbuilds/GIS/libLAS/libLAS-1.8.1/apps/las2col.c:1048:9: warning:
passing argument 1 of ‘fsync’ makes integer from pointer without a cast
[enabled by default]
fsync(files_out[i]);
In file included from
/opt/slackbuilds/GIS/libLAS/libLAS-1.8.1/apps/las2col.c:30:0:
/usr/include/unistd.h:978:12: note: expected ‘int’ but argument is of type
‘struct FILE *’
extern int fsync (int __fd);
Linking C executable ../bin/Release/las2col
/usr/lib/gcc/i486-slackware-linux/4.8.2/../../../../i486-slackware-linux/bin/ld:
CMakeFiles/las2col.dir/las2col.c.o: undefined reference to symbol
'pthread_join@@GLIBC_2.0'
note: 'pthread_join@@GLIBC_2.0' is defined in DSO /lib/libpthread.so.0 so
try adding it to the linker command line
/lib/libpthread.so.0: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make[2]: *** [bin/Release/las2col] Error 1
make[1]: *** [apps/CMakeFiles/las2col.dir/all] Error 2
make: *** [all] Error 2
Please advise how I should fix this problem.
TIA,
Rich
More information about the Liblas-devel
