[Liblas-devel] LASzip issue in libLAS. Extra Bytes not supported?
Howard Butler
howard at hobu.co
Mon Apr 10 18:08:12 PDT 2017
Thanks for the report Martin. There is indeed a bug in libLAS' LAZ support when files have extra bytes in them.
Filed here. https://github.com/libLAS/libLAS/issues/119
Howard
> On Apr 6, 2017, at 1:24 PM, Martin Isenburg <martin.isenburg at gmail.com> wrote:
> Hello,
> apparently the attached compressed LAZ file does not survive the round trip via libLAS' las2las ... can someone verify (or explain / debug)?
> C:\OSGeo4W64\bin\las2las -v paul.laz --output paul_liblas.laz
> E:\LAStools\bin>lasinfo -i paul.laz
> lasinfo (170330) report for paul.laz
> reporting all LAS header entries:
> file signature: 'LASF'
> file source ID: 0
> global_encoding: 0
> project ID GUID data 1-4: 00000000-0000-0000-0000-000000000000
> version major.minor: 1.2
> system identifier: 'LAStools (c) by rapidlasso GmbH'
> generating software: 'txt2las (version 170402)'
> file creation day/year: 96/2017
> header size: 227
> offset to point data: 1451
> number var. length records: 2
> point data format: 1
> point data record length: 35
> number of point records: 5024
> number of points by return: 3051 1503 411 57 2
> scale factor x y z: 0.01 0.01 0.01
> offset x y z: 4300000 5600000 0
> min x y z: 4376272.35 5683751.73 452.29
> max x y z: 4376671.84 5683959.33 484.91
> variable length header record 1 of 2:
> reserved 0
> user ID 'LASF_Spec'
> record ID 4
> length after header 960
> description 'by LAStools of rapidlasso GmbH'
> Extra Byte Descriptions
> data type: 3 (unsigned short), name "echo width", description: "Full width at half maximum [ns]", scale: 0.1, offset: 0 (not set)
> data type: 4 (short), name "LAS 1.4 scan angle", description: "additional attributes", scale: 0.006, offset: 0 (not set)
> data type: 1 (unsigned char), name "LAS 1.4 extended returns", description: "additional attributes", scale: 1 (not set), offset: 0 (not set)
> data type: 1 (unsigned char), name "LAS 1.4 classification", description: "additional attributes", scale: 1 (not set), offset: 0 (not set)
> data type: 1 (unsigned char), name "LAS 1.4 flags and channel", description: "additional attributes", scale: 1 (not set), offset: 0 (not set)
> variable length header record 2 of 2:
> reserved 0
> user ID 'lascompatible'
> record ID 22204
> length after header 156
> LASzip compression (version 2.5r2 c2 50000): POINT10 2 GPSTIME11 2 BYTE 2
> reporting minimum and maximum for all LAS point record entries ...
> X 7627235 7667184
> Y 8375173 8395933
> Z 45229 48491
> intensity 10 346
> return_number 1 5
> number_of_returns 1 5
> edge_of_flight_line 0 0
> scan_direction_flag 0 0
> classification 0 0
> scan_angle_rank 0 0
> user_data 0 0
> point_source_ID 3 5
> gps_time 0.000000 0.000000
> number of first returns: 3051
> number of intermediate returns: 470
> number of last returns: 3051
> number of single returns: 1548
> overview over number of returns of given pulse: 1548 2184 1062 220 10 0 0
> histogram of classification of points:
> 5024 never classified (0)
> E:\LAStools\bin>lasinfo -i paul_liblas.laz
> lasinfo (170330) report for paul_liblas.laz
> file source ID: 0
> global_encoding: 0
> header size: 227
> offset to point data: 8774
> number var. length records: 3
> variable length header record 1 of 3:
> reserved 0
> user ID 'LASF_Spec'
> record ID 4
> variable length header record 2 of 3:
> reserved 0
> record ID 22204
> variable length header record 3 of 3:
> reserved 43707
> user ID 'liblas'
> record ID 7
> length after header 7269
> description 'http://liblas.org/schema/'
> LASzip compression (version 2.2r0 c2 50000): POINT10 2 GPSTIME11 2
> ERROR: 'end-of-file during chunk with index 0' after 1638 of 5024 points
> X -2140398450 2143434216
> Y -2141878466 2146152511
> Z -2145714721 2146156107
> intensity 0 65535
> return_number 0 7
> number_of_returns 0 7
> edge_of_flight_line 0 1
> scan_direction_flag 0 1
> classification 0 31
> scan_angle_rank -128 127
> user_data 0 254
> point_source_ID 3 65498
> gps_time -0.000000 0.000000
> WARNING: range violates GPS week time specified by global encoding bit 0
> WARNING: 1637 points outside of header bounding box
> number of first returns: 467
> number of intermediate returns: 352
> number of last returns: 922
> number of single returns: 391
> WARNING: real number of point records (1638) is different from header entry (5024).
> WARNING: for return 1 real number of points by return (230) is different from header entry (3051).
> WARNING: for return 2 real number of points by return (230) is different from header entry (1503).
> WARNING: for return 3 real number of points by return (193) is different from header entry (411).
> WARNING: for return 4 real number of points by return (189) is different from header entry (57).
> WARNING: for return 5 real number of points by return (188) is different from header entry (2).
> WARNING: there are 237 points with return number 0
> WARNING: there are 180 points with return number 6
> WARNING: there are 191 points with return number 7
> overview over number of returns of given pulse: 182 258 208 223 179 198 181
> WARNING: there are 209 points with a number of returns of given pulse of 0
> 67 never classified (0)
> 51 unclassified (1)
> 54 ground (2)
> 55 low vegetation (3)
> 63 medium vegetation (4)
> 64 high vegetation (5)
> 46 building (6)
> 54 noise (7)
> 35 keypoint (8)
> 40 water (9)
> 41 rail (10)
> 54 road surface (11)
> 49 overlap (12)
> 53 wire guard (13)
> 36 wire conductor (14)
> 46 tower (15)
> 62 wire connector (16)
> 41 bridge deck (17)
> 54 Reserved for ASPRS Definition (18)
> 42 Reserved for ASPRS Definition (19)
> 52 Reserved for ASPRS Definition (20)
> 52 Reserved for ASPRS Definition (21)
> 69 Reserved for ASPRS Definition (22)
> 33 Reserved for ASPRS Definition (23)
> 57 Reserved for ASPRS Definition (24)
> 67 Reserved for ASPRS Definition (25)
> 55 Reserved for ASPRS Definition (26)
> 52 Reserved for ASPRS Definition (27)
> 59 Reserved for ASPRS Definition (28)
> 39 Reserved for ASPRS Definition (29)
> 52 Reserved for ASPRS Definition (30)
> 44 Reserved for ASPRS Definition (31)
> +-> flagged as synthetic: 841
> +-> flagged as keypoints: 855
> +-> flagged as withheld: 804
> real max x larger than header max x by 21357670.320000
> real min x smaller than header min x by 21480256.850000
> real max y larger than header max y by 21377565.780000
> real min y smaller than header min y by 21502536.390000
> real max z larger than header max z by 21461076.160000
> real min z smaller than header min z by 21457599.500000
> <paul.laz><paul_liblas.laz>_______________________________________________
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
