[rttopo-dev] librttopo 1.1.0 released
Sandro Santilli
strk at kbt.io
Sat Jul 27 00:03:35 PDT 2019
Version 1.1.0 of the RT Topology Libarry is ready for download:
http://download.osgeo.org/librttopo/src/librttopo-1.1.0.tar.gz
The RT Topology Library exposes an API to create and manage standard
(ISO 13249 aka SQL/MM) topologies using user-provided data stores and
released under the GNU GPL license (version 2 or later).
More info can be found from
https://git.osgeo.org/gitea/rttopo/librttopo
=== What's new in this release ===
Important / Breaking Changes:
- Support for tolerance/precision=0 added, -1 is the new value
for automatic computation of minimal tolerance.
- The getEdgeWithinBox2D backend callback needs to support a NULL
value as BBOX pointer (to return all edges)
New Features:
- Function `rtt_AddLineNoFace`, to add lines w/out determining new
faces (WARNING: leaves topology in an invalid state)
- Function `rtt_Polygonize`, to determine all faces generated by
existing edges.
- Function `rtt_tpsnap`, to snap linear components of a geometry
to edges of a topology.
Happy packaging !
--strk;
More information about the librttopo-dev
