[Live-demo] LiveDVD from GISVM?
Massimo Di Stefano massimodisasha at yahoo.it
Wed Aug 12 07:25:10 EDT 2009
Hi Cameron,
this is the way i'm following.
i'm using a linux distro installed on a VM (virtualbox)
then from it i create the live.iso using remastersy basckup utility.
i had to hack a bit remastersy to have it working on sidux too.
why sidux :
sidux has already preinstalled a virtual environment,
so when you start the live.iso inside a VM
it will have the "base" virtualbox addition already Working.
This means :
- mouse can go outside the vm screen
- 3d sw ( like ossimplanet) working in a live session
- screen expanding.. etc
but i also had, in the live.iso desktop, a ditrectory with the
virtualbox addition installer.
it is needed beacouse any upgrade that touch the kernel ... needs a
new virtualbox addition installation.
i have an updated live.iso disk image, i uploaded it to darkblue_b
(irc frrenode)
to a berkeley univ. computer so him can do simple test and see if all
works as aspected
(the live do not has all the geo-sw installed, beacouse i need that it
go under testing first.
if we don't have boot and driver problems, i can go ahead to customize
it)
tell me if you want try it, let me know if i can upload it to you.
ciao,
Massimo.
Il giorno 11/ago/09, alle ore 08:49, Cameron Shorter ha scritto:
> Ricardo,
> I wonder whether it would be possible to cut a Live DVD image from
> the GISVM virtual machine image?
> If so, this could be an effective way to share the maintenance of
> the LiveDVD and GISVM, and share communities.
> Is this possible, and what would be involved to make this happen?
> Cameron Shorter
> Geospatial Systems Architect
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo mailing list
