[Live-demo] LiveDVD from GISVM?
Cameron Shorter
cameron.shorter at gmail.com
Thu Aug 20 05:30:04 EDT 2009
Ricardo,
Further to Stefan's comments, Stefan currently has some time which he
can dedicate to the Live DVD, and we'd like to see if we can build the
Arramagong Live DVD from a GISVM base.
This will probably involve porting some functionality currently in
Arramagong over the GISVM, which in turn should bring the two projects
together and mean we are both maintaining the same codebase.
Ricardo, what would be the best way for Stefan to help you. Is there a
way for him to effectively contribute to your GISVM desktop edition?
Stefan Hansen wrote:
> Hi Ricardo!
> Ricardo Pinho wrote:
>> Hi Stefan,
>>> Its version number is 2008.11.01
>>> That means it was created November
>>> last year, doesn't it?
>> Yes, that's right!
>> I advise you to make your tests on it.
>> Remenber, don't upgrade... (only if strickly necessary)
>>> Do you actually have a more recent
>> I'm working on it, not ready to deploy (only has a few installed
>> desktop apps)
>> For sure I can only garantee to make available for you at the end of
>> this month!
>> Is this ok for you?
> As far as I can tell that should fit in our time line. We should still
> have enough time to try to turn the VM into a LiveDVD for Foss4g.
>>> And if not, how hard would it be to create a desktop
>>> version from your current server version?
>> Hmm it is possible but I prefer to build a desktop version from scratch.
>> It lacks several components that you will need to install by hand.
>> I have an update version of GISVM Server almost ready to upload.
>> (just needs some clean and compress actions)
>> In a few days (probably this weekend) you can download it...
>> So I suppose you are the one that have been working on Arramagong,
>> right?!
> Yep, I worked on it, though I was not the only one.
>> You have done a good job on it,
> Thanks! I was actually quite impressed by your VM. :-)
>> I will appreciate your recomendations and contribuitions to improve
>> GISVM.
> I generated today an ISO-image from your VM and things went actually
> quite smoothly. :-D However, I came across a few things that would make
> my life easier, but are not essential for the functionality of your VM:
> On the desktop version of the VM you had installed most of the
> applications into the home folder of the user. Since home gets loaded
> completely into the memory, when you boot from a DVD, this has quite an
> impact on the performance and memory requirements. Is it possible for
> you to install the apps somewhere else or am I too late with this
> request?
> Can you increase the size of the HD? It's a bit too small for generating
> the ISO.
> Are you actually planning on putting sample data and examples for each
> application on the VM? We had that partially on the LiveDVD and made it
> much more useful for demonstration purposes.
> cheers,
> stefan
>> Please keep in touch, I will try to answer asap!
>> Regards,
>> Ricardo
>> ----- Mensagem original ----
>> De: Stefan Hansen <stefan.hansen at lisasoft.com>
>> Para: Ricardo Pinho <rpinho_eng at yahoo.com.br>
>> Cc: "live-demo at lists.osgeo.org" <live-demo at lists.osgeo.org>
>> Enviadas: Terça-feira, 18 de Agosto de 2009 2:02:07
>> Assunto: Re: [Live-demo] LiveDVD from GISVM?
>> Hi Ricardo,
>> I'm just downloading your latest desktop-version of the GISVM, so I can
>> try to create an iso-image from it.
>> Its version number is 2008.11.01. That means it was created November
>> last year, doesn't it? Do you actually have a more recent
>> desktop-version? And if not, how hard would it be to create a desktop
>> regards,
>> stefan
>>> Cameron,
>>> I was reading:
>>> http://wiki.osgeo.org/wiki/FOSS4G_2009_Press_Release_11
>>> "FOSS4G Live DVD:
>>> LiveDVDs, based on the Xubuntu operating
>>> system and including Geospatial Open Source Software, will be given to
>>> all delegates. Users can boot a Live DVD on their computer and trial
>>> the software without installing or effecting the existing system. "
>>> And it remind me to propose to Live Demo initiative a Free
>>> Distribution of GISVM on the same or different physical DVD to all
>>> delegates.
>>> So users would benefit of having one more alternative to run and try
>>> FOSS4G!!!
>>> The only thing I ask for is to FOSS4G 2009 support the DVD
>>> production costs.
>>> And I would compromise to deliver a GISVM special edition for FOSS4G
>>> 2009 (just like I have done for FOSS4G2008...)
>>> Cheers,
>>> Ricardo Pinho
>>> De: Ricardo Pinho <rpinho_eng at yahoo.com.br>
>>> Para: live-demo at lists.osgeo.org
>>> Cc: Cameron Shorter <cameron.shorter at gmail.com>
>>> Enviadas: Quinta-feira, 13 de Agosto de 2009 0:05:54
>>> Cameron,
>>> Thank you for asking…
>>>> I wonder whether it would be possible to cut a Live
>>>> DVD image from the GISVM virtual machine image?
>>> Well, as far as I know there are a million ways to build a Live CD.
>>> In theory you
>>> can make a Live CD out of any running Linux OS.
>>> ( http://wiki.osgeo.org/wiki/Creating_a_Live_GIS_DISC_from_scratch )
>>> Never
>>> thought much about that, but making a Live CD out of a Virtual
>>> Machine must also be possible!
>>> One way has already been proposed by Massimo...
>>>> If so, this could be an effective way to share the maintenance of
>>>> the LiveDVD and GISVM, and share communities.
>>> Yes, GISVM and
>>> LiveDVD have many things in common.
>>> And I know
>>> some projects that have both distributions: Live CD & Virtual Machine.
>>> Just an example
>>> “IcAROS”: http://aros.sourceforge.net/download.php
>>> Until now,
>>> I really haven’t thought seriously about building a Live CD on the
>>> GISVM
>>> project.
>>> Because there are already several similar solutions out there and, I
>>> believe, it
>>> must focus on Virtualization. (the future… ;-)
>>> However, I’m
>>> building a completely new GISVM Desktop version, right from scratch.
>>> So we could
>>> join forces and work together.
>>> It would be wonderfull to see FOSS4G programmers involved on making
>>> GISVM a better solution for users.
>>>> Is this possible, and what would be involved to make
>>> this happen?
>>> Well, to
>>> make it happen, first I need to know more about Live GIS Disc
>>> initiative:
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>> The first
>>> version I knew about, was Lorenzo’s, Omniverdi Live CD:
>>> http://livecd.ominiverdi.org/
>>> I suppose FOSS4G
>>> 2007 and 2008 Live DVD where made out of it.
>>> This year,
>>> for FOSS4G2009, OSGeo and Lisasoft changed it to “Arramagong”
>>> http://www.arramagong.com/
>>> So, Live
>>> DVD is now sponsored by OSGeo and Lisasoft:
>>> http://www.arramagong.com/Arramagong/Sponsors.html
>>> And that's what I know about it.
>>> GISVM is just
>>> an interesting idea that I decided to put online, out of my spare
>>> time and pocket.
>>> At
>>> my current situation, I can’t afford the time and money necessary to
>>> enter on a
>>> bigger project.
>>> But I will
>>> gladly consider any proposal, from OSGeo or other, about something
>>> concerning building
>>> together a LiveCD and Virtual Machine for FOSS4G.
>>> Regards,
>>> Ricardo
>>> Pinho
>>> http://gisvm.com
>>> De: Cameron Shorter <cameron.shorter at gmail.com>
>>> Para: "live-demo at lists.osgeo.org" <live-demo at lists.osgeo.org>
>>> Enviadas: Terça-feira, 11 de Agosto de 2009 7:49:16
>>> Assunto: [Live-demo] LiveDVD from GISVM?
>>> Ricardo,
>>> I wonder whether it would be possible to cut a Live DVD image from
>>> Is this possible, and what would be involved to make this happen?
>>> -- Cameron Shorter
>>> Geospatial Systems Architect
>>> Tel: +61 (0)2 8570 5050
>>> Mob: +61 (0)419 142 254
>>> Think Globally, Fix Locally
>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>> http://www.lisasoft.com
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> ____________________________________________________________________________________
>>> Veja quais são os assuntos do momento no Yahoo! +Buscados
>>> http://br.maisbuscados.yahoo.com
>> Stefan Hansen
>> Software Engineer
>> LISAsoft
>> Ph: +61 3 8680 3200 Fax: +61 3 8680 3299 Mob: +61
>> Level 9, 601 Bourke St, Melbourne Vic 3000
>> LISAsoft is part of the A2end Group of Companies
>> http://www.ardec.com.au
>> http://www.terrapages.com
>> The contents of this email are confidential and may be subject to
>> legal or professional privilege and copyright. No representation is
>> made that this email is free of viruses or other defects. If you have
>> received this communication in error, you may not copy or distribute
>> any part of it or otherwise disclose its contents to anyone. Please
>> advise the sender of your incorrect receipt of this correspondence.
> Stefan Hansen
> Software Engineer
> LISAsoft
Cameron Shorter
More information about the Live-demo
