[Live-demo] Chat Cameron/FrankW re using OSGeo Blade Server and
Windows Installers
Hamish
hamish_b at yahoo.com
Wed Aug 26 09:05:13 EDT 2009
> <FrankW> The telascience blades are generally underpowered to run
> an actual virtual machine if that is what you were thinking.
> <CameronShorter> The alternative, might be to have the VM mounted
> as a directory, so that we can access the VM directory for
> synchronisation.
> <FrankW> I guess I'm not familiar with how that would work - just
> mounting the iso as a file system?
If you mount an ISO as a filesystem on the server you will probably
want to do it as a normal user. The "mount -t iso9660 -o loop"
method requires you to be root. To mount as a normal user you should
install "fuseiso", then add the user to the "fuse" group and run:
fuseiso -p file.iso mntpoint.$$
to unmount do:
fusermount -u mntpoint.$$
(someone on the SAC would need to make sure fuse was installed and
whoever's user account was added to the fuse group)
Note that a ISO9660 is a complete filesystem and as such can not be
modified inline (readonly). To make changes to one you have to unpack
it somewhere (fuseiso mount + cp -r), make your changes, then mkisofs
or eqiv. to pack it back up.
No idea about mounting VM images. but,
Alex Mandel wrote:
http://www.jameslittle.me.uk/how-to-mount-vmdk-files-in-linux/
> I'll try it out at work tomorrow and see how it goes. Note it requires
> that you have the vmware software to do this and the vm must be off.
> This method looks a little more recent and seems compatible with VMware
> and VirtualBox and relies on VirtualBox.
> http://forums.virtualbox.org/viewtopic.php?f=7&t=17574
One thing I am concerned about is how to avoid colisions? AFAIK rync/
unison are not really peer-to-peer setups and I can picuture the
situation closer to the deadline when two people are working on the
image at the same time and the binary gets out of sync / corrupted.
As this is not under any sort of revision control I'm not sure how a
manual checkout/checkin status system could be maintained. As long as
it is a small group of people that might happen over email+ lots of
discipline.
so keep daily backups locally, eh?
anyone wishing to edit(rsync) the file will need user-level access
to the host server, it would not be a good idea to leave that open
for any 3rd party on the internet to modify. (again no easy rev.
history to check)
and I guess we only assume rsync won't mind file sizes which push the
limits of 32bit integers, and will keep req'd transfers to a minimum.
oh well, only one way to find out!
> <CameronShorter> We can include a directory of Windows Installers
> on it, or whatever else you suggest.
AFAICT the disk needs a D:\osgeo4w_installers\ (or so) directory off the
root dir -of the disk-. Depending on how you do it, the root dir a
liveDVD 'may' exist in a compressed subdir of the ISO filesystem, only
viewable once booted -- no good for a combined MS-Windows installer
handout. when we get to the point of burning DVDs we need to double
check that goes in the right place :)
within that we'd need the main osgeo4w_setup.exe and a pool/ subdir
with all the binary packages. We either need to cut a custom setup.exe
which knows where to look on the disc by default (instead of net downloads),
a wrapper script that sets the local pool dir as a command line option to
the installer (Install_from_disc.bat), or just a well placed README.html
with step by step instructions on how to tell the installer to look on
the disc for the packages instead of the internet.
best,
Hamish
More information about the Live-demo
