[Live-demo] install_grass.sh script from Hamish
Alex Mandel
tech_dev at wildintellect.com
Thu Aug 27 03:29:33 EDT 2009
To get very recent versions of Grass/QGIS with ECW, Mrsid etc use the
UbuntuGIS ppa
https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable
deb http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu jaunty
main
deb-src http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu
jaunty main
Note, that in order for the QGIS Grass plugin to work right you have to
grab a set that was compiled together, for the gdal-grass-plugin and the
qgis-grass-plugin.
Alex
Stefan Hansen wrote:
> Hamish,
> thanks for the script! Unfortunately the version apt-get is trying to
> download is according to your script to old! :'(
> Which repository provides something more recent?
> cheers,
> stefan
> Cameron Shorter wrote:
>> I've put Hamish's install_grass.sh script into svn (he seems to have the
>> same access issues I had).
>> Stefan, can you please test the script out today, and adjust if
>> required. I suspect data files are being installed into the home
>> directory, and should be installed elsewhere.
>> Hamish wrote:
>>> <snip>
>>> ps- (untested) grass script is done, I'll move it into
>>> gisvm/trunk/bin/ once that is back on our turf. for now I've
>>> attached it to this email. (for some reason my svn access died
>>> on that part of the server; which is kind of weird because my
>>> admin rights are still intact. it must have fallen away during
>>> the recent rebuild. oh well, I'll sort that out....)
> Stefan Hansen
> Software Engineer
> LISAsoft
> Ph: +61 3 8680 3200 Fax: +61 3 8680 3299 Mob: +61
> Level 9, 601 Bourke St, Melbourne Vic 3000
> LISAsoft is part of the A2end Group of Companies
> http://www.ardec.com.au
> http://www.lisasoft.com
> http://www.terrapages.com
> The contents of this email are confidential and may be subject to legal
> or professional privilege and copyright. No representation is made that
> this email is free of viruses or other defects. If you have received
> this communication in error, you may not copy or distribute any part of
> it or otherwise disclose its contents to anyone. Please advise the
> sender of your incorrect receipt of this correspondence.
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo
