[Live-demo] install scripts
Stefan Hansen stefan.hansen at lisasoft.com
Thu Aug 27 23:52:58 EDT 2009
Hamish wrote:
> Hi,
> quick questions WRT fine tuning the build scripts-
> - what version of Xubuntu is being used?  9.04?
Yes, it is 9.04
> - what's the username set to? i.e. to use /home/user/ or /home/gis/ or
>    /home/ubuntu/ or ...?  This is to know where to write ~/.config files
>    as the script will be run as root. (so ~ means root's home, not the
>    user)
The username is 'user'.
> - these scripts are being run in a chroot/virtual environment, right? ie
>    if I write a file to /usr/local/ it goes on the VM's filesystem one?
Yep, I think that's the case.
cheers,
stefan
> thanks,
> Hamish
> ps- I've made some edits to the press release. The wiki page will let you review them by clicking on the history tab.
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
Stefan Hansen
Software Engineer
LISAsoft
Ph: +61 3 8680 3200 Fax: +61 3 8680 3299 Mob: +61
Level 9, 601 Bourke St, Melbourne Vic 3000
LISAsoft is part of the A2end Group of Companies
http://www.ardec.com.au
http://www.lisasoft.com
http://www.terrapages.com
The contents of this email are confidential and may be subject to legal or professional privilege and copyright. No representation is made that this email is free of viruses or other defects. If you have received this communication in error, you may not copy or distribute any part of it or otherwise disclose its contents to anyone. Please advise the sender of your incorrect receipt of this correspondence.
More information about the Live-demo mailing list
