[Live-demo] Version numbers
Ricardo Pinho
rpinho_eng at yahoo.com.br
Thu Oct 1 20:15:51 EDT 2009
> Richardo,
> For the virtual machine, we have been adding "gisvm" into the tag.
> Ie: arramagong-gisvm-2.0.3
> Do
you want gisvm to be specifically associated like the above,
> or do you
want to create a separate gisvm which is different from arramagong?
> Eg: We could have:
> arramgong-vm-2.0.3
> andgisvm-2.0.3.1 or similar.
> What are your thoughts.
You all have done a GREAT WORK on this community project!
(I probably missed a lot because I couldn't keep up with you)
But this is how I see things :
This Live-Demo initiative had a clear objective: To produce a LiveDVD for FOSS4G 2009! (following the tradition of previous events)
But on that process, you have used VM to build it, to discover the potential of Virtualization.
I really agree that FOSS4G should start to have a VM alternative distribution. Attendees will benefit a lot from it!
So to make both versions related (because they are!) to the public, I really
think you should use the same prefix:
arramagong-2.0.3-livedvd.iso
arramagong-2.0.3-vm.7z
If you think that using GISVM name can in anyway benefit this release, I will not oppose on using it (for example):
arramagong-2.0.3-gisvm.7z
But I really don't want to be accused of using others work on the benefit of GISVM name.
It has been a pleasure to help you guys, the best I could, and to see the success of it.
And since you have build a VM final version for this event, I really don't see the point of making a GISVM release for it!
Unless it has a completely new approach, like GISVM Server! (that's why I have released it)
GISVM has it's own life, and I will try to make it last for many other FOSS events.
Sometime after the FOSS4G2009 there will be a new GISVM version out of the existing scripts!
Because there are many things to improve...
In the mean time I will download 2.0.3 version, and hope to have deep look on it this weekend.
And you can count on my comments and suggestions if I find anything to wrong.
Cheers,
Ricardo Pinho
http://gisvm.com
----- Mensagem original ----
De: Cameron Shorter <cameron.shorter at lisasoft.com>
Para: tech at wildintellect.com
Cc: "live-demo at lists.osgeo.org" <live-demo at lists.osgeo.org>
Enviadas: Quinta-feira, 1 de Outubro de 2009 23:06:34
Assunto: Re: [Live-demo] Version numbers
Alex, minor suggestions re naming convention, (I've been following what I believe to be close to ubuntu conventions)
* Only use lower case.
Use:
arramagong-livedvd-2.0.3 (note no "Final" in the name)
In retrospect, I suspect we should have:
arramagong-2.0.3-livedvd.iso rather than arramagong-livedvd-2.0.3.iso
Richardo,
Do you want gisvm to be specifically associated like the above, or do you want to create a separate gisvm which is different from arramagong?
Eg: We could have:
arramgong-vm-2.0.3
and
Alex Mandel wrote:
> For those who have access to the download server edit the index.html,
> please keep in mind that file is in svn, so it's best if you make
> changes on your machine, commit them and then svn up on the osgeo
> server. Otherwise edits may be lost, clobbered or otherwised mixed up.
> FYI, 2.0.3-Final links are now active.
> No torrent till we resolve best approach. VM's sometime over the weekend.
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
-- Cameron Shorter
Geospatial Systems Architect
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
____________________________________________________________________________________
Veja quais são os assuntos do momento no Yahoo! +Buscados
http://br.maisbuscados.yahoo.com
More information about the Live-demo
