[Live-demo] Does your application work on the click2try GISVM?
Cameron Shorter
cameron.shorter at lisasoft.com
Mon Oct 12 16:42:28 EDT 2009
Aneel wrote:
> Hello Cameron and Osgeo team,
> After screening all the mails till now , we have listed out the issues
> mentioned by osgeo members.
> Some of the issues we have already fixed in multilayer gisvm. They are
> 1. There are no icons for deegree
> 2. There is no mapserver icon
> 3. The "Start Mapnik & TileLite" icon is missing
> 4. There is no "MapTiler" icon
> 5. #494: Remove screen saver on click2try image
> 6. #495: click2try VM user/password should be same as LiveDVD
> Pending issues to be fixed and we are trying to fix it. If you have
> any information please let us know
> 1. GeoNetwork - it doesn't work
> 2. The desktop icon using launchassist.sh is rigged specifically to the
> password user on the sudo command. That's probably why it didn't work.
I believe these 2 issues are related.
Now that you have changed user/password to user/user, I suggest
re-running the install_geonetwork.sh script:
sudo ./install_geonetwork.sh 2>&1 | tee /var/log/arramagong/install_geonetwork.log
> Developers who are re-testing, can do modification as they want on
> click2try image (Vm) and please let us know the changes to fix them
> permanently.
> How to access gisvm:
> URL http://www.click2try.com
> user id : osgeo
> password : livedemo
> Once logged in, navigate to My Dashboard -> Applications Manager. You will see
> a VM named osgeo-gisvm20-2. Hilite that and click the red LAUNCH button. This will connect you to the VM
> Gnome Desktop user credentials:
> user id : user
> password : user
> One another point, this running vm is build using
> "branches/arramagong_2" and please find below errors (got while
> Installation)
> Error1:
> cp: omitting directory `/usr/local/share/grass/spearfish60/user1/dbf'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cats'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cell'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cell_misc'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/cellhd'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/colr'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/colr2'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/dbf'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/fcell'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/g3dcell'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/hist'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/vector'
> cp: omitting directory `/usr/local/share/grass/nc_spm_08/user1/windows'
> Adding user `user' to group `users' ...
> Adding user user to group users
> Done.
> 2009-10-09 17:22:41
> URL:http://svn.osgeo.org/grass/grass/trunk/gui/icons/grass-48x48.png
> [2407/2407] -> "grass-48x48.png" [1]
> Finished installing GRASS 6.4.
> Error2:
> Warning messages:
> 1: In getDependencies(pkgs, dependencies, available, lib) :
> package 'pkgDepTools' is not available
> 2: In getDependencies(pkgs, dependencies, available, lib) :
> package 'Rgraphviz' is not available
> > q()
> Error3:
> https://svn.osgeo.org/osgeo/livedvd/gisvm/branches/arramagong_2/doc/descriptions/maptiler_description.html:
> 2009-10-09 19:16:33 ERROR 404: Not Found.
> Note: Please do not shutdown testing vm.
> We will wait for your feedback.
> Regards
> Aneel
> On Mon, 2009-10-12 at 13:16 +0200, Eric Lemoine wrote:
>> On Mon, Oct 12, 2009 at 12:24 PM, Cameron Shorter
>> <cameron.shorter at lisasoft.com <mailto:cameron.shorter at lisasoft.com>> wrote:
>> > Eric,
>> > On the click2try VM, could you please:
>> > svn update install_mapfish.sh
>> it looks like I don't have the permissions to svn upate
>> install_mapfish.sh in /usr/loca/share/gisvm/bin. Were you thinking
>> about something else?
>> Thanks,
>> > sudo ./install_mapfish.sh 2&>1 tee /var/log/arramagong/install_mapfish.log
>> > # Verify that mapfish works
>> > Eric Lemoine wrote:
>> >> 2009/10/10 Cameron Shorter <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>>:
>> >>> Tom tells me I can forward this email to the public live demo list now.
>> >>> So
>> >>> please reply to this list.
>> >> Hi
>> >> Mapfish isn't installed properly in the click2try virtual machine. The
>> >> virtual machine was installed before Hamish did an important change to
>> >> install_mapfish.sh it seems. What should we do?
>> >> Thanks,
>> > Cameron Shorter
>> > Geospatial Solutions Manager
>> > Tel: +61 (0)2 8570 5050
>> > Mob: +61 (0)419 142 254
>> > Think Globally, Fix Locally
>> > Geospatial Solutions enhanced with Open Standards and Open Source
>> > http://www.lisasoft.com
Cameron Shorter
More information about the Live-demo
